Question about Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher
When dishwasher is set to begin, sensor takes very long period of time. Cycles are longer than minutes indicated. Dishwasher fills with water but does not wash. Water then drains as though cycle is complete and moves to next cycle. Then the process continues. When cycle for drying is reached, much heat is given and occasionally it smells as though there is burning. A 82 minute procedure turns into hours.
    Top Expert:
  • Kenmore Master
  • 77,499 Answers
It sounds like you need to replace the dishwasher control panel.
Posted on Jul 25, 2017
4 Suggested Answers
  • 90 Answers
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
  • 1891 Answers
SOURCE: kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Posted on Nov 22, 2009
  • 3247 Answers
SOURCE: Dishwasher fills with water.
Looks like the pumps are not working. Please provide the full model number of the dishwasher.
Posted on Dec 12, 2010
Dishwasher takes a very very long time to wash
It could be that it takes a long time for hot water to reach the dishwasher so it fills with cold water. the control may wait for the water to warm up before advancing. Try running the water at the sink until warm before turning on the dishwasher. This may fix the problem. Some models have a water turbidity sensor and will wash until the water is clear. Excessively dirty dishes will cause extended run cycles.
Oct 07, 2014 | Dishwashers
Dishwasher will fill w/water but will shut off b4 cycle begins
Have you unplugged it for about 20 minutes yet and tried again?
Dec 28, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
I have a GE PDW8400JO3BB dishwasher.It use to take 53 minutes to do a normat load and now takes 83 minutes. Why
There could be a few reasons for this..
Most likely the water temperature is not reaching the optimum temperature required for cycle.
The incoming water supply pressure could be lower which means it takes longer to fill.
The turbidity sensor might not be functioning properly causing the dishwasher to prolong the wash cycle.
Best to run the dishwasher empty with a Finish dishwasher cleaning kit that you can purchase from the supermarket. The instructions are written on the kit.
this should help clean dirt from all the sensors that are located in the tub.
Hope this helps.
May 16, 2011 | GE Dishwashers
Is it possible that when I set the dishwasher to normal or automatic, the cycle takes over two hours!! I think it was 136 minutes. MUCH longer than any other dishwasher I've ever had
Yes, many dishwashers now will take at least two hours and some more depending on various things that ti checks as it is washing...
With the newer detergents and cooler water temps. the cycles are getting longer...to do the same job...
heatman101
Mar 07, 2011 | Thermador 24 in. DWHD94BP Built-in...
TAKES A LONG TIME,
Takes a long time to what? If the entire cycle seems to take forever, one suggestion is to make sure your hot water heater is turned up. Most dishwashers requires the water to be a minimum of 120 degrees before the timer will begin. If you are using a Sani-Wash cycle, then the water need to heat up to 165 degrees. The heater can only heat the water 1 degree per minute, so if the water coming in to the dishwasher is only 100 degrees, it will take an additional 65 minutes before it will even start the cycle. You can also make sure you get the water at the sink hot before you start the dishwasher, this will ensure the hottest water is going in (only fills for 90 seconds).
Jul 30, 2010 | KitchenAid KUDR01TJ Dishwasher
Dishwasher cycles are taking too long
usaully water temperature is the major reason why a dishwasher takes longer this could be due to the water tank.To verify this open hot water valve and let it run on your hand and count the seeconds it takes to get so hot your hand has to pull out. Between 10 to 20 sec normal, 20 to 30 means dishwasher has to heat it up and this takes longer but acceptable. 30 to 60 this would really impact the time of your cycles. Now regarding the sauce pans this surprises me this could be the dishwasher internal water heater which would let be belive that water level is too low or even absent you need to let it fill up and while it is operating stop it open the door and see if water covers the heater. I do recomend that you schedule a technical service expert to verify your unit
Mar 20, 2009 | AEG 24 in. Favorit 40660i Built-in...
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Wash cycle
momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Nov 30, 2007 | Kenmore 24 in. 17512 Built-in Dishwasher
Dishwasher keeps running
I have seen this several times, and all of the times it has a bad control board. usually if you take the control board out, you can see a visibly burnt spot on the back of it wher a connection has melted. Another possible slowrun time problem could be that the water coming into the dishwasher when it fills is not hot. If it isnt hot, it takes the dishwasher longer to heat the water to temp, and therfore it runs longer. Is the water coming out of your tap reasonably hot? if not you may need to turn up your water heater settings. But if nobody has messed with the water heater, or the tap where the dishwasher is attached and the problem just started then thats probably not it. Good Luck!
Aug 04, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
