Question about Whirlpool Dishwashers
I have a whirlpool dishwasher model DU1055XTPQ4 and the cleaning light remains on. The manual says check heating circuit does this mean the element is burnt out
  • 188 Answers
SOURCE: whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
  • 3 Answers
SOURCE: plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Posted on Dec 01, 2008
mastatech
  • 478 Answers
SOURCE: How to replace a heating element on a Whirlpool dishwasher
remove kick plate, look inside the tube to see where the element goes thru the tube. there are two plastic nuts, turn off power, disconnect wire terminals, remove nuts, pull old element thru inner tube, relace in reverse order.
Posted on Mar 12, 2009
SOURCE: whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Posted on Mar 13, 2010
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
Whirlpool GU1200 XT Dishwasher Will not
Press the [Menu] Soft key in standby mode and press
[*] key within 3 seconds to lock the keypad. Keypad lock
remains unlock if [*] is press after 3 seconds.
May 30, 2008 | Whirlpool Dishwashers
Model 665.1602 Blinking green(clean) light. Manual says it's a heater circuit problem. What should be replaced?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 11, 2011 | Kenmore 24 in. 17692 Built-in Dishwasher
Clean light flashing on my dishwasher
If you have a Whirlpool ( or Kenmore made by Whirlpool) the light indicates a problem with the heating element circuit. You can test the element with an ohm meter and visually inspect the wiring to the element. If the element checks out ok, then be sure there is enough water in the d/w during the whole cycle. If all this checks out , you may need a new control board.
Jan 13, 2011 | Dishwashers
The
usually means u need service if u got your manual see if it mentions it, try to flip the breaker or power to it maybe it willl resets..... if u can find the tech sheet or wiring diagram on the unit maybe below behind kick panels somwhwere it might mention it,,,,,, i beleive sometimes that means ur heating element as gone out on some models,,, also some had 5 year part warrranties on the heating element... do not remove once u do u must replace that element.....hope this helps
Jan 31, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Whirlpool dishwasher ADP6000WH Error 3
Jan 15, 2009 | Dishwashers
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
113 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
