Question about Hayward H Series Induced Draft Abg 100,000 Heater
Leak from both top and bottom of the recessed area which holds the thermol coupler senor bulb inside the copper water priping
    Problem Solver:
  • 15 Answers
Not sure i quite understand, but if your saying the water is leaking from the copper heat exchanger, then you need to replace the exchanger itself. Not cheap.. but do-able. 9 times out of 10 a leaking heatexchanger is caused by chemical abuse ( low pH)
Posted on Aug 22, 2010
How to change thermostat
the radiator is filled to the top with coolant and the engine is run without the radiator cap in place, the coolant will expand and spill over as the engine warms up.
  • Drain some coolant into a clean container until the coolant level is below the thermostat housing.
  • Remove the upper radiator hose connection from the thermostat housing.
  • Loosen the housing bolts and remove the housing.
  • Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
  • Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
  • The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
  • When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
  • Install the gasket.
  • Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
  • When the engine has reached operating temperature make sure the thermostat opens.
  • You should be able to see coolant circulating within the radiator.
  • Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
  • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stu
    CAUTION
    If the radiator is filled to the top with coolant and the engine is run without the radiator cap in place, the coolant will expand and spill over as the engine warms up.
    • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
    NOTE When a paper gasket is used and the recess is in the thermostat housing, it is a good practice to position the thermostat into the recess and glue the gasket to hold it in place. If it falls out of its groove during installation, the outlet housing can be cracked or a coolant leak will result. Before tightening the water outlet housing, try to rock it back and forth to be sure it is flush. Housings are often cracked during this step.ck closed and must be replaced.
May 07, 2012 | 1998 Mercury Mystique
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Water is coming out of the nipple around theb hot water oulet
If it is an old water heater it may be a leak at the weld . If it is a newer water heater it may
just need tightening, OR shut off water to the heater itself and shut off power, open a hot
faucet or tub and connect a hose to the drain of the water heater. Drain about a bucket
worth of water from the heater before removing the threaded nipple to apply some
pipe thread seal or teflon tape. I recommend using rectorseal on the nipple and port. From
what you describe it is the nipple itself and not the popoff. If it is the popoff then the
procedure is the same for it's removal (they are replaced only and not serviced)
If the nipple has copper line to it you may need to cut it with a tubing cutter and use
a compression coupler (usually 3/4 inside diameter but sometimes 5/8 inside diameter)
The inside diameter of the coupler will be the same as the outside diameter of the pipe.
These are readily available at any home improvement retailer.
make sure to refill tank until water flows at tap before restoring power.
Feb 26, 2011 | Water Heaters
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
Jan 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Water leaking inside of the fridge from the top
It sounds like your frost-free freezer is cycling through its normal defrost mode, which allows the cooling assy. to be deiced and that melted ice (water) will run out and down to the drain in the bottom of your fridge.
Aduz
Mar 27, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
We have a leak in the back bottom of our refrigerator , ice maker
You say there was a new copper line attached? I assume that this means a repair has been done. If the unit has been slightly overcharged with refrigerant, this can cause excessive condensate to build up on the return copper tubing and would then drip in the back of the fridge. Or you should check on the drainpipe which often has a drainpan built either over the compressor dome or somewhere within the compressor area. Make sure the drainpipe is not missing the pan and that the pan is not leaking.
Mar 09, 2009 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Thermol coupler
Take the Thermo Couple out and take it to a hardware store and match it up. Most are all the same.
Feb 16, 2009 | B&K Water Heaters
Leaking water
It probably does need to be replaced IF it is leaking from the bottom. It MAY, however, be leaking at the top and just dripping down to the bottom. If it only leaks when you're filling the cup, then it probably is a top leak. These are generally easily fixed by getting a new slip-on connecter to connect the copper tube connecting the faucet to the nipple on the top of the tank. to remove the connector, push the rings on the ends of the connector (where the tube enter it) towards the other end. Buy the replacement at Home Depot or Lowes before starting to see how it works.
Dec 01, 2008 | Select Brands Elkay LKH190BK The Hot Water...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hayward H Series Induced Draft Abg 100,000 Heater Logo
168 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
