Question about Poulan "Poulan" Push Mower
I have a Poulan Pro push mower with a 550 series Brigss and Straton. It's never cut grass well, but that aside, the engine runs like ****. My son usually is the one using it. I've removed the fuel tank and carb, cleaned and re-installed, no better. Rumor has it if the blade hits something hard, there is a piece at the bottom of the motor designed to break to save the engine, and this may be the cause. Any thruth to this?
  • 755 Answers
As far as running poorly. You should check the quality of your fuel and make sure your fuel can hasnt collected water. This happens a lot with todays fuels. If you arent sure. Dump the fuel into a vehicle and let the can dry out completely and buy fresh alcohol-free gas. Also dump the fuel from the mower.
Make sure the air filter isnt over oiled. You can do this by removing it and squeezing out any excess oil.
This mower should never have been fitted with a mulching blade.
The engine is too small. It would probably cut grass better if it were a bagger but then it would be way harder to push.
The mower has a collar that holds the blade on the keyed shaft.
If it hit something hard enough it could sheer this key. But then the mower wouldnt cut grass at all.
You should make sure your blade isnt on backwards. Sometimes they get assembled by someone who forgets the blades go on either way. Some manufacturers actually put edges on both sides to take advantage of this fact.
With your spark plug wire off of the spark plug tip the mower up and look at the blade. Do you see the beveled edge facing away from the chute opening? If so you should remove the blade and turn it over.
Good luck and be careful.
Posted on Aug 22, 2010
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Engine started smoking real bad, it still starts
Could be just a head gasket, also could be rings. Could also be oil in the gas or bad gas overall. Empty out the gas, change the oil, and try again. If it does the same thing take it to service shop.
Sep 29, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan "Poulan" Push Mower Logo
294 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
