I have an Amana high Efficiency 12 air conditioner, model #RCC60A2B that is not cooling. If I have the fan on it blows out room temp air, if the fan is on auto it does not blow anything. Also the remote condensing unit fan does not turn on even though the thermostat has the fan on.
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
  • 132 Answers
SOURCE: Fedders window unit won't blow cool air
Hi There,
It needs to be re-charged with freon.
Posted on Mar 28, 2009
  • 44 Answers
SOURCE: adjusting thermostat temperature
nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
Posted on May 28, 2009
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
My Amana ptac unit is blowing air but it's not coming out of the unit as cold as it should therefore never reaching the desired temp of 65...does my unit need 2 be recharged or are lines froze...???
it's known as the split. Room air going into the unit should be 10 to 12 degrees cooler coming out. Unit size, area to be cooled, insulation value and local weather are considered. If the split is close to the numbers the unit is doing all it can. If it's low on freon the evaporation coils will freeze and ice over.
May 23, 2015 | Amana Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Need owners manual online what is the auto button for
Auto enables the unit to adjust the temp automatically as temp in the room changes. It will change to cool mode or high fan according to the temp in the room.
Aug 01, 2011 | Maytag M7Y15F2A Air Conditioner
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
Blows cool air
This is normal. To maximize the units efficiency the fan continues to run until all the heat from the coil is pasted to the circulating air.
May 24, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
