Question about Compaq Presario CQ60-220US PC Laptop
Someone borrowed my computer and it came back with a black screen. It powers on but nothing else. Can you suggest what to try?
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 22, 2010
Flat screen has gone black but sound is fine
Suggest that you borrow a monitor from someone and try it on your system. If it works , you may have a defective backlight on your monitor , which means that you may want to replace the monitor. If the replacement monitor also is black , you probably have a video output problem , which would require repair of your computer.
Dec 01, 2014 | Bush Televison & Video
Screen is black
If you're getting just a flashing cursor on a black screen it's probably a motherboard/video card/hard disk problem (probably motherboard).
If there's not even a flashing cursor - just a black screen - you can add a failed power unit to your list of problems.
The easiest way to check is to borrow a power unit and video card from a friend's computer. There's no need to remove your existing power unit. Simply disconnect the power cables from the motherboard and connect the spare power unit in its place.
If your computer powers up it is obviously a faulty power unit to blame. IIf there's still nothing on the screen, power down the computer and replace the video card with the spare one. If there's still nothing on the screen when you power it up then in all probability your motherboard is history
Nov 29, 2013 | HP Computers & Internet
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
Black screen after changing resolution
Try setting your resolution back to the way it was and see what happens.
Maybe your monitor or video card is bad.
To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor, then the video card inside the computer is bad.
May 18, 2012 | Dell Computers & Internet
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
Will power on but nothing on the screen. Screen is black. Was going fine day before. turned it back on & nothing
it could be a problem supply. See if you can borrow a power supply to test this first.
Dec 27, 2009 | Computers & Internet
My HP DV1000 will not start.
You have a power issue. The board is not charging the system or the battery. If you know someone with a similar model, ask them if you can borrow their battery and see if your system boots with it. If it does, you may need a new adapter or the power board in the notebook is out. When you remove the battery and try it, there's enough juice to power it up for the moment, but not sustain it.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Compaq Presario CQ60-220US PC Laptop Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
