Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do i change setting only to print black - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
    Scholar:
  • 122 Answers
Hello lsmith473, Here is how to set your printing preferences to black ink only:
  • From your Desktop: Click Start-->Control Panel
  • Double click Printers and Faxes
  • Right click your printer and select printing preferences
  • You should be able to set black ink only on that window or in one of the tabs.
Please reply with any issues or rate this solution if you found it helpful. Thanks! Edward
Posted on Aug 22, 2010
P50 dose not print black color
You might have to run the head clean more than once - if no black at all is printing.. Alternatively, set out a page of all black (background) and print few pages on high print quality setting.
good luck!
Feb 17, 2015 | Epson P50 Inkjet Printer
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
Black text Printing using Photo Black
You should be able to set the cartridge it uses when you print, as something like 'Print only black'. Fish around in the printer window when it comes up when it comes up. You may also be able to set this as a default in 'Properties' from the 'Printers' option in Windows, but then it will always try to do this, of course, which you may not want.
Jun 26, 2009 | Canon MP610 Photo All-In-One Printer
I want to print with black ink only. Where do I
what are you trying to print?
You will need to change your printer settings ... go to the properties of the printer and then select printing prefrences there should be an option to just print black and white only ...
Also this model will not print if either cartridge is empty ... black and colors are necessary to be full .. but you can change and set the default to be black only
Mar 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
