Question about Kenmore 24032\24036 Top Load Washer
Goes throught washing cycle then stops. Will not drain and go to rinse cycle
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Aug 22, 2010
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
I need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you
Reply to rutledge5135 on Apr 11, 2011
(i need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you)...
The 'S' is for 'Spray' which happens at the beginning of the Spin Cycle...it then goes on to rinse etc.
regards, avery.phill@gmail.com
Apr 11, 2011 | Hoover Washing Machines
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Won't drain water for rinse
your lid switch is defective..replace onthejob
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
