My psc 1610 all-in-one printer has an error message stating carriage jam. Can move it manually all the way across and electrically as well. Have gone through reset procedures, checked carriage for obstuctions (none) observed,attempted to print test page, it says it is printing but is not moving or printing. Ed Williams
  • Edwin J Williams Aug 22, 2010
    Dan, Have done what you asked still no luck, tried to print both a test page and a Dianogstic page still no luck, again it says its printing but is not. Have check interior of printer front and back I do not see any paper or obivious jams. what now?
  • 4,323 Answers
Hi
Please check for any paper jam inside the printer. All paper jams must be removed from the back of the product through the rear access door. Pulling the paper from the front of the product rotates the paper feed roller in the wrong direction and can damage the product. Open the print cartridge access door, and then wait until the print carriage is idle and silent. Make sure the printer is turned on. Remove the ink cartridges and inspect the carriage for small bits of paper. Now turn off the printer and unplug it. After unplugging it use a Q-tip and apply motor oil on the chrome bar. After this reset your printer, and will function normally. Hope this helps... If it does please do not forget to accept the solution or post back for assistance. Daniel
Posted on Aug 22, 2010
  • Daniel Scott
    Daniel Scott Aug 22, 2010
    Hi
    While using a standard A4 paper, make sure that the paper guides are adjusted properly and that the paper is pushed well up to the back. Try to turn it upside down if you can and shake it a bit, such that any loose paper bits would fall out. Now try and locate the area near the printhead, where the ink is ejected from the cartridge. It looks like a piece of plastic with little yellow of gold bumps on it. Be sure you don't touch this area with your fingers. Take a Q-tip and dip it in alcohol and wipe this area. A couple swipes across it should do. Then inspect the matting area on the cartridge carrier. If this still doesn’t resolve the issue then open the clamshell as if you were changing the inks (power off) and remove the back hatch. With all this open, look over all of the small wheels and pinions, and the larger rubberized wheel that actually picks up the paper, making sure that there isn't any crud or clutter in the way, and that the pickup wheel feels just tacky enough to actually grab the paper.
    Daniel
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer carriage keeps jamming what i going on?
the paper you are using is dampy and wet. you need a new paper that is clean and dampy free (i.e not wet) GOOD LUCK
Jun 18, 2010 | HP PSC 1610 All-In-One InkJet Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Print Cartridge Carriage Stalled
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage Jam
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 17, 2008 | HP PSC 1610 All-In-One InkJet Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
