Question about Car APS95BT2 2-Button Code Learning Transmitter
I have a 1997 honda accord with an aftermarket audiovox car alarm installed. I want to disable the alarm or at least disable the kill switch. The key fob is going bad, I do not have a manual. It is not easy to start my car. I open the door with the key. The parking lights flash and I hear a clicking. If I press the black button on the key fob, it will disable the alarm but a second later will arm it again. Sometimes it arms while I'm driving. Anyway, I was to leave the door open and disable the alarm and the car would start. Now it takes me about 15 minutes to start my car because the alarm keeps activating and deactivating on its own. I am not sure what combination of button to turning the key in the ignition works when I actually do get it started
    New Friend:
  • 13 Answers
Look for some sort of toggle switch associated with the alarm system. (something small similar to this []) They call this a valet switch and it's located somewhere hidden and out of the way - usually under the dash - but still in an accessible spot. This basically disables the alarm. Typically, you'd turn the key on (but engine off) then flip the switch. This will put the car into valet mode and basically disable it. There is also usually some sort of LED light associated with the system - again typically blinking when the system is armed - but it will be solid once in valet mode. The clicking you are hearing is the relay that is triggering things. I'm assuming someone got tired of the alarm sounding and got rid of the siren it or clipped the wires to it - hence why your only hearing the clicking and seeing the light flash.
I have a 1997 honda accord with an aftermarket - 7000_toggle_series_new_spl-o2gligydpufgz2rcrizkl4c3-5-0.jpg
Posted on Mar 31, 2017
5 Suggested Answers
  • 50 Answers
SOURCE: My Audiovox prestige alarm won't accept new fobs
Posted on Jan 22, 2010
  • 11 Answers
SOURCE: Audiovox Pursuit Pro keyfob reprogram
if thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
Posted on Jul 26, 2010
  • 1455 Answers
SOURCE: I have a new prestige APS-57C remote starter
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Posted on Jan 25, 2011
  • 139 Answers
SOURCE: remote start only starts with key in the ignition
It sounds like the immobilizer bypass module has either lost its programming due to the dead battery or a voltage spike from jump starting/recharging the battery or it has malfunctioned. Without knowing which module is installed, it is not possible to determine if it can be reprogrammed. The immobilizer bypass module substitutes the transponder that is in your key and allows the vehicle to start. When it is malfunctioning, it may not be providing a signal or providing the wrong signal the vehicle ECU is expecting. The reason you can remote start the car with the key in the ignition is because the transponder is being read fromthe key and the ECU is allowing the vehicle to start.
Posted on Dec 03, 2011
How do I disable my car alarm in my 91 Honda accord dx I dont have the stock keys new ignition the car just kills and wont restart for a while and runs roughbafter driving it for awhile
I don't believe that the 1991 Accord DX had a Honda accessory alarm option, but regardless, factory or aftermarket, it was wasn't installed at the factory, it was installed at the dealer or an aftermarket store. Just remove it, and reattach any cut wires.
Apr 03, 2015 | 1991 Honda Accord
How do I disable the alarm or kill switch on my Alarm
In the installation instructions it will describe which wire in the cars loom to reroute to alarm. Find out and rejoin this wire.
This is considering it is aftermarket alarm
Aug 19, 2014 | Cars & Trucks
Disable alarm
usage? b
did you loose the guide. its here
it automaticaly sets when you lock the car.
so you want to defeat the auto set. ,
Honda dont want you to....
the MICU does that. it is fully integrated into the cars systems.
includes, door left open warnings, etc.
if you attempt to kill it, many bad things will happen.
i suggest asking HONDA that question.
drive there , ask service, if it can be done.
the manual does not mention defeating it .
Dec 09, 2013 | 2006 Honda Accord
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
My 97 Honda accord se wont turn over, and car alarm keeps going off
the alarm is the fault refer to your alarm manual to disable it, if you don't know about this unit it is best to seek help from someone qualified and available to look at it for you, it seems as if your alarm is set, most alarms have a starter disable function and the alarm going off is an indication that it is set.
May 18, 2012 | 1997 Honda Accord
I am trying to install my aftermarket alarm in my 1997 honda accord. the installation guid give the picture of key and written ACC. so where should i connect that wire and what colir will be that...
I can't really remember what color the wire was but, if you get a light tester and look for the wire that lights up the tool when you turn your ignition on to the turn the radio on....Good luck!
Feb 10, 2011 | 1997 Honda Accord
Which fuse is for the car alarm on a 1990 Honda Accord?
1990 Accord didn't come with a factory alarm option. You must have an aftermarket alarm installed and the fuse for that alarm will be on the red wire, very close to the actual alarm brainbox. That brainbox should be located under the dashboard somewhere, normally on the drivers side, but it all depends on where the installer decided to put it. :)
Oct 08, 2010 | Honda Accord Cars & Trucks
Where is the valet switch for honda accord 2002 lx?
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the driver’s side. Some alarms have different sequences that you have to go through to put the alarm into valet mode; it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilized, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Thank You for contacting
Aug 03, 2009 | 2008 Honda Accord
Car APS95BT2 2-Button Code Learning Transmitter Logo
210 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
