Question about Brother MFC-5840CN All-In-One InkJet Printer
Printer turns off unexpectedly after few minutes then back on?
When i push on button it turns on and goes thru its cycles then after a few minutes suddenly shuts off and the turns back on by itself. wont print either . when i try to copy somthing it turns off then when it turns back on the paper comes out blank. ink cartridges are full.
  • 832 Answers
Defective main printer board. needs replacing. if machine is still in warranty call brother. otherwise get rid of it because spare part is very expensive.
Posted on May 04, 2008
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
I have a problem with the FAN setting on my AC. It has 3 settings -Auto-High-Low. It cycles thru all 3 settings and keeps beeping as it cycles thru - its doing this almost continuisly every so often it...
The thermo stat its self no good if this is a house issue. Had the same problem. Went to lowes and got a new one. The old one pulls out and the new goes in its place. No wire touching. If u can find a close match. If its a car a/c good luck never even seen a auto feature in a car. Only high med low.
Jun 24, 2011 | Heating & Cooling
HL-1440 We had an unexpected power outage and now the drum light blinks then all 4 lights blink. I try to push the reset button and nothing. It was working fine prior to the outage. It it just a local...
Try this solution.
* Turn your printer off.
* Hold in the circular button on the front panel of your printer.
* Turn your printer back on.
* When the drum light is lit by itself let go of the button.
* Hold in the circular button on the front panel again.
Once the Alarm light comes on, let go of the button.
Your printer should now be reset.
Hope this help you.
Aug 03, 2010 | Brother Office Equipment & Supplies
C6180 All-in-one: On-off loop never stops
while the printer is on remove the power cable from the printer then press # and 3 on the printer together and then while pressing the buttons insert the power cord n then leave the buttons
if still problem persists then try the same thing by pressing # and 6
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
RCA RT2250 consistant shutting off in Satalite mode.
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
May 15, 2007 | RCA RT2250 System
Brother MFC-5840CN All-In-One InkJet Printer Logo
171 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
