Question about Samsung NC10-14GW Notebook
MY nc10 does not work when it is not plugged into the charger. It always says 0% remaining. Could I possibly need to get a new battery?
    Sergeant:
  • 238 Answers
First check when connected to charger battery charging is ON or OFF. If ON then you need a new battery. if possible arrange a working battery & check if works fine, then change the battery. if not working then motherboard need to check.
Posted on Aug 22, 2010
NC10 battery always shows 0%
Try replacing the battery as it may be exhausted.
Jan 17, 2016 | Samsung NC10 Netbook
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
Aspire 5935 G plugged in not charging 0% aviable
If you are sure the charger is OK, then the possible cause could be the battery or the power jack.Take the battery out, and plug in the charger, if your laptop works, then the power jack is OK, you need to replace the battery; If not, then it proves the power jack is broken, it need to be resoldered or placed. Or you could directly test your battery with a digital multimeter.
Mar 31, 2012 | Computers & Internet
Battery not charging samsung nc10- was OK the other day now just intermittent blue flash when plugged in. unplug and no power. removed battery and charger works. Fn F2 00% battery life!!- do you think a...
try holding the power button for 30 secs with the battery out and unit powered off it allows a static discharge and might help its what my wifes g60 requires from time to time good luck and hope this helps you out some
Mar 22, 2011 | Samsung NC10-14GW Notebook
My samsung nc10 screen goes white whilst charger plugged vin
the lcd cable that joins the screen to the motherboard is most probably faulty under AC power input. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jul 29, 2010 | Samsung NC10-14ROBL Notebook
Although tradesman moterhomde plugged into electrical, engine's battery loses power, any suggestions as to why?
I am assuning you have an operation (read "working") isolation switch in your system. Such a switch (mechanical or electronic) will isolate your coach battery from your chassis batery. If you dont drive the vehicle often, it is possible for your chassis battery to go dead while the coach battery remains in tip top condition. (Coach is always on "charge". Im going to guess your chassis battery is not new.
Of course when you drive, you charge the chassis battery and in some installations, you also charge the coach battery. You dont want the coach battery to run the chassis - think about it and you will understand why. Other installations provide a switch that will allow you to start the vehicle with the coach battery if required.
If you dont go out often, consider a small trickle charger for your chassis battery. Since you keep your motor home plugged in, you have 110 V AC power available in the coach. Just plug your small trickle charger into the motor home and charge your chassis battery. Remember to disconnect the charger before you start the coach.
Safe travels. Let me know if this helps.
A
Sep 21, 2009 | Measuring Tools & Sensors
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
IBM thinkpad t42 new Battery "On line, critical"
The only way is to continue using it that way till it will not go off when you unplug.
The charger might have gone bad too.
Try the first method then replace charger.
Mar 18, 2009 | IBM ThinkPad T42 Notebook
Targus ac70u adapter; 0% available, ( plugged in, not charging )
How old is your laptop? It may just be that you need a new battery if it won't hold a charge.
Further, this charger worked previously on this laptop and with this battery? If so, you definitely might be ready for a new battery.
Dec 29, 2008 | Umax ActionBook 333T Notebook
Samsung NC10-14GW Notebook Logo
265 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
