Question about Mitsubishi VS-50111 50" Rear Projection Television
I was given a Mitsubishi vs-50111 I was told all it needed was to be adjusted due to the color being out of alignment however i let the tv sit for 3 days and when i plug it in i get nothing when i try to turn it on. I shecked out the power cord and it works fine also i checked each of the fuses and each is ok. what can i check next? i am hoping tofind out if the set is fixable or if i should just pitch it away,
  • Mitsubishi Master
  • 1,216 Answers
You need to be concerned about the convergence board. This is the board with all the RCA jacks and RF connections. Pull this board out. You will see two very large cooling fins [heat sinks] with two large ICs [black with about 15 pins each. Marked with #392 ---] I don't know the exact# right now. Replace these Ics. And check the small resistors that stand tall next to theses Ics, replace if necessary! Let me know what you find.Thanks for asking me!
Posted on Aug 22, 2010
I have a model VS 50111 and the colors are out of alignment blue shadow to left yellow to right. Can I fix this problem
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
Apr 14, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Colors out of alignment
If you have background in electronics, you can do it. The difficult part here is on how to access those convergence amp(convergence circuit output IC). By replacing those 2 IC and some resistors sometimes, adjust the convergence and your done. Good Luck
Mar 05, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
All three colors are off by an inch or two can i fix it or is this a pro's job
The Convergence Circuit has failed and a Professional would be needed to fix it.
Hope this helps,
Skyassoc
Jul 16, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to figure out diagnostic code
wat is the code ???
is it Error code 2-3
if so check q5a01 and 03 thrue to q5a06
also replace T5a31 PN/340p216010
Jan 14, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS-50111 50" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
