Question about Kitchen Ranges
Hotpoint ew83 main oven stopprd heating, fan and light ok but no heat from element
  • Anonymous Jan 18, 2009
    Exactly same - what did you do?
Hotpoint EW83
1. Safety Fusible Link Blown (O/C) Do continuity test
2. Temperature Control Module Faulty (Heat Sensor)
3. Main Heating Element Blown (O/C) Do Continuity Test
4. Check for damaged wiring due to arcing etc.
5. Fetch the Proff!
Posted on Feb 21, 2009
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Hotpoint bu 82, main fan oven not heating but the temp light and fan are ok just no heat. what would be the most likely cause, and how can i repair thanks
It is going to be the fan oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
This is a very easy repair to do.
Mar 17, 2010 | Ovens
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
Jul 21, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint oven heating element
check stat not open circuit and check selector switch not damaged
Aug 20, 2008 | Smeg SE250XUK Stainless Steel Electric...
Hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Feb 22, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Kitchen Ranges Logo
315 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
