Question about Maytag Atlantis MDE6400AY Electric Dryer
My dyer wont stay on once i pull the knob - Maytag Atlantis MDE6400AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Need to remove a gear shifter from a 2003VW passat
gear shifter as transmission inside it. well best replace transmission or you'll need a pulley and few sockets. as the shift. the shift you pull the knob or act as if you are prying it out it stay out. once out far enough push down on the bottom sparkling part of the stick. once down pull knob. then fallow the screw on side for removal.
Mar 15, 2014 | 2003 Volkswagen Passat
My oven wont stay on but grill still ok but they work off same knob
it could be the thermocouple, you can get uiversal thermocoulpe from mmost plumbers merchants , b and q etc.fairly easy to fit ,any probs drdrop me a line
Dec 06, 2012 | Indesit Gas Cooker Spark Ingniter Unit...
I have a Kenmore dryer model 110.66642500. The timer knob pulled off and I have tried to put it back on but it just pulls off every time. The part number is 3956789. Can I just get another knob or do I...
You can buy the knob individually. Most likely what happened to yours, is there is a metal insert in the shaft of the knob. If that insert detatches and pulls out, it wont stay on the timer shaft anymore.
Hope this helps.
Sep 25, 2011 | Kenmore Dryers
My choke cable wont stay out when i first start the bike so it dies. How do i adjust it? Or do i need a new one?
There is an adjustment on the cable. If you pull the knob out, you'll see a another knurled knob just behind it. If you turn the knob clockwise, it should put more tension on the enricher cable. Never put any kind of oil or other lubricant on the enricher cable. Be careful when tightening the tension knob as the parts are made of plastic and break easily. If it breaks, you must pull the carburetor in order to replace it.
Good Luck
Steve
Mar 09, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
My toast lever wont stay down-I've loosened the cover and cleaned as best I can. How can I take the lever off so that I can fully remove the cover? It is a Cuisinart two slice black toaster.
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
Jan 26, 2011 | Cuisinart Kitchen Appliances - Others
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
When we go to turn the dryer on it makes a buzzer sound, how so we make the dyer work?
Is it the same buzz that goes off when the load is finished? The knob may be broken, if so what you need to do is pull it off and see if the handle knob is really turning the smaller knob, if it isn't, replace the knob.
If the knob is fine then you have a problem with your controls and you need someone with electrical experience to look at it.
Mar 13, 2010 | Kenmore 400 6943 Dryer
My gaggia classic frother is stuck and cannot turn the black knob
pull the knob to you, take it out than grab the valves axe with wrech or pliers, to prevent braking the black knob and open the valve.
after you opened it once it should work perfect.
ps these valves seal metal to metal and when thay stay long without working thay can do this.
Mar 09, 2009 | Gaggia Classic Espresso Machine
My whirlpool LGQ8611LW1 Dyer won't start.
Johnny i dont know the machine, but with photos i might be able to help
May 10, 2017 | Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
