Question about Movado 800 Performance watch
In reading the movado 800 quartz chronographic instruction manuel there are 3 settings for the crown. the first is the one in which you generally wear it. the second position states it will stop the watch and this where you set it. however later in manuel it states that the second position will allow the time to continue but allows you to adjust the hour hand. on my watch the time only stops completely after pulled all the way out to the third position. this allowed me to set the watch. my question is should the time stop in the second position or only when pulled all the way out to the third. thankyou
    Problem Solver:
  • 8 Answers
The time should only stop when the crown is pulled all the way out in the third positiion... In the second position the 2nd hang should continue to tick and you should only be able to move the hour hand on the watch
Posted on Dec 09, 2010
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
I have a Movado 800 Series (Spec no. 8819176 or 84 C5 1897). I didn't wear it for a while and now when I try to use it aagain it doesn't work. Could it be something to do with the battery or it runs on a...
That watch has a quartz movement and most likely needs a new battery. Take it to a jeweler or to Sears for the replacement. It only takes a few minutes and should coat about $10.
Mar 13, 2011 | Movado 800 Performance watch
Hello I have a movado 800 series sub 200 and
it is probably either in set time mode, or some sort of chronograph mode. play with the buttons.
Feb 19, 2011 | Movado 800 Performance watch
The chronograph hour hand on my movado series 800 is out of sync and i cant get it back to the 0 position. I have pulled out the crown and pushed the start/stop button...
Try pulling the crown out and using the reset button to move hands beside the sweep arm. If this doesn't work then you may need to take it to a repair shop that can reset or AC the watch. With a movement as fine as Movado I wouldn't attempt this yourself. If you make a mistake the repair could cost more than the watch. Be sure that you have the watch resealed so it maintains its water resistance.
Feb 10, 2011 | Movado Series 800 Watch
Just bought this watch today (movado 800 series) and the second hand (hand C) doesnt move at all. It is part of the chronograph function. It is stuck at the 9 oclock position. When chronograph is...
I wouldnt try to return it. I would go back and inform the store of the problem you have and they have no choice but to either fix it, show you how to solve the problem, exchange it, or at the least, return it but please give them a chance to fix the issue.
Best wishes,
Aug 16, 2010 | Movado® Series 800 Blue Chronograph Watch...
How do u you set the date on movado series 800 steel watch
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point
Jul 27, 2010 | Movado 800 Performance watch
My movado was cleaned and still does not work, works for short , thenit stops
Assuming it's not a quartz watch try winding it fully - about 40 turns of the crown. If you wear it daily it won't need further winding unless you skip a day or you're not very active. The watch is typically wound by the movement of your arm/wrist. Manual winding will compensate for the lack of movement.
Apr 14, 2010 | Movado 0604869 Watch for Women
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Reset tank franchase cartier
Not completely sure what is being asked.
If what is being asked is how to reset chronograph hands to their zero point on a quartz watch then do the following:
1) Pull the crown out to the setting position.
2) press the chronograph buttons. Each one will move a different hand.
3) Once the hands are set push the crown back in.
Normally the zero point needs to be reset after a battery change or if the battery in the watch is getting weak.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Cartier Tank Francaise W50005R2 Watch for...
My Movado Series 800 second hand zeroes out at the 3-second spot, not at zero (12).
The chronograph can be reset by pulling out the crown to the first or second position and pressing the start button or top button. This will begin to move the sweep arm and you can stop it on the 12:00 or 0 position. Make sure that when you have the battery changed they do this for you.
Sep 17, 2009 | Movado Series 800 Watch
Movado 800 Performance watch Logo
447 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
