Question about Magic Chef Refrigerators
How can i recharge my magic chef mcbr 360s? - Magic Chef Refrigerators
4 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
Some technicians tried that, they just replace the compressor oil. But I did try that yet.
Posted on Jan 02, 2008
heatman101
  • 43501 Answers
SOURCE: Magic Chef Model MCBR 1020w
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 18, 2010
slick45836
  • 61 Answers
SOURCE: I have a Magic Chef
Sorry to inform you, but the compressor is out, the reason it kicks off is because the motor is trying to turn the compressor but the compressor is tied up and the motor heats up and shuts down. not cost effective to replace the compressor.
Posted on Jun 16, 2011
How to recharge magic chef HMBR350SE1
HAHAHAHA they are not rechargeable units try unplugging and plugging in again ,check the main breaker .
Oct 28, 2015 | Magic Chef Microwave Ovens
I have a Magic Chef Refridge MCBR 1010W that has stopped cooling, fan runs and you can hear it kick in but then kicks off? An Ideas?
If the compressor kicks in that tells you the compressor relay and board are probably good. HOWEVER, when you say it kicks off right away that is not a good indication! It sounds like a compressor problem. Is the compressor extremely hot or is the condenser coils icing up? If so, I wouldn't invest the money into repairing it, because it would cost more to repair than to replace.
Jun 16, 2011 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef Model MCBR 1020w refrigerator making a clicking noise.
heatman101
Nov 17, 2010 | Magic Chef CTB1502AR Top Freezer...
Is there a replacement part for the freezer compartment in a Magic Chef MCBR360S? Mine is damaged and leaked coolant and fridge no longer cools.
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Aug 22, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Magic chef- apartment size
The unit is sealed most tecks will not recharge to small to deal with. Most common cause for this is low freon. If someone has a clamp on amp meter the wire leading to the compressor will probibly show very low amps. showing a free flow compressor. Cheaper to replace.
Oct 23, 2007 | Magic Chef CTF2125 Top Freezer...
Refrigerators Logo
63 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
