Question about Olevia LT32HVM 32 in. LCD Television
Plasma problems pioneer pdp433hde on powering up both the media box and screen leds turn green but then the screen led flashes a sequence of 5 flashes pauses then repeats the cycle. the media box led remains green so assume the fault lies with the screen. any help would be great. pioneer are no help in spite of us retailing their products. and having our own service dept. their solution is to sent the unit to one of their asc. trouble is that costs hundreds. one has to ask where is the backup from them seems to me, there is non. when i turn the power on the led light turns green for a half a second then it turns red and blinks 5 times over and over again. Can i personally fix it? If not how much will it cost to fix it?
  • Anonymous Dec 28, 2008
    I have a 42 inch Plasma Panisonic TH42PC77U that displays green,red,blue,yellow verticle bars and continues flashing...sound is good.
    D
    Problem Solver:
  • 6 Answers
Possible defective Digital Assy.
Posted on May 09, 2008
    Genius:
  • Olevia Master
  • 1,689 Answers
Most of the repairs on these sets are done by board replacement. After the defective board located sometimes there are some adjustments that have to be done.
Most of the repairs are done by process of elimation when board swaping is done to find the defective board. This is a much faster approach rather than analazing waveforms with a scope and taking voltage readings to determine the probabability of what board failed. Sometimes a fault can be determined, and the actual failed components are located on another board from where the readings were taken.
At home, it would not be practical for you to buy a full compliment of spare boards for process of elimination type repairs, and you would not have the facilities to peform the factory level adjustments if required.
The bottom line, is that you should give the set in for factory service if you want it properly serviced. Guessing at a fault and buying parts to try will be a lot more exensive.
Jerry G.
Posted on May 04, 2008
Pioneer PDP-435HDG will turn on, and I get a test pattern type screen for a couple of seconds, then monitor turns off. Media receiver unit is flashing the green power led in a 7 flashes pattern. Hel
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 11, 2015 | Pioneer Televison & Video
Pioneer PDP - RO6U Plasma: Says starting up, please wait when turning on. Can't get past this screen. I have tried unplugging and plugging everything back in and am still getting the same error. Are...
unplug it from the power for one hour. Than Press and hold the power button on the on the TV for 20 seconds(It wont show anything. Than Release the power button....
After that plug the power and check the same...
Sep 14, 2008 | Pioneer Televison & Video
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Pioneer PDP 4330HD display flashes red LED 4 times
Just seeing if you had resolved the problem as my mum's Pioneer PDP-433HDE which she bought back 2002 has developed this same fault.
It has been a perfect TV and done very well with plenty of good use, but I have a feeling the cost of repair - even if it is possibale will be costly.
Cheers
Nigel
Mar 13, 2010 | Pioneer PureVision PDP-4330HD 43 in....
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Plasma problems
HI
THANKS FOR YOUR QUICK REPLY. I NOTICE YOU ARE BASED IN THE USA, I AM IN THE UK (JUST ACROSS THE POND) ARE YOU ABLE TO ASSIST ON THE UNITS THAT ARE SOLD HERE. IF YOU CAN THEN IT MAY WELL BE WORTH SUBSCRIBING BEST WISHES DAVE FOX.
Mar 07, 2008 | Pioneer PureVision PDP-4330HD 43 in....
Olevia LT32HVM 32 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
