Electronic piano, yamaha pf80, bought new 1985-6. Push in the power switch to turn on, and the piano works fine. After about 2 or 3 minutes, it cuts out - as if it had been unplugged. Cycle the power switch (push in to turn off, and in again to turn back on), and again it plays as normal, but then it cuts out again, after maybe 30 seconds. The nearest Yamaha repair shop is 40 miles away, and they want a $60 bench fee just to look at it. I can't risk that much (time, effort & money) just to find out it's not worth fixing. Perhaps the power supply unit (built in, not the cord-adapter-plug type) has gone bad. Is there a way I could determine that at home? I'm no electronics wizard, but if I knew it was the PSU and could find the part, I'd try to replace it myself.
  • 395 Answers
SOURCE: Will only power-on after multiple atempts.
That problem is well known problem with a memory capacitor on the stand up board that is the control board. It is .47F 5.5 volt capacitor that resembles a button battery. The cap leaks all over this board the fluid is conductive and corrosive. So the cap must be removed and the board scrubed clean with contact cleaned and dried before replacing with new cap. the unit can run without this cap but if the power should be removed all customer settings will revert to the default. also check the copper ground screws for tieghtness.
Posted on Jul 08, 2007
dthomas1969
  • 4 Answers
SOURCE: Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Posted on Feb 07, 2009
SOURCE: Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
Posted on Jul 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Amp RX-V1700B Receiver - no power to head unit
Go to the shop.
Posted on May 28, 2010
Testimonial: "Thanks - I came to the same conclusion myself - hopefully something simple and not too expensive."
dunnbiker
  • 8546 Answers
SOURCE: Hey got a yamaha rxv650
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 01, 2011
Sustain Pedal works intermittently.
To start with always best to use the correct power supply these should be readily available from any good Yamaha store. Is the sustain pedal a Yamaha pedal? The plug end of the pedal connect a multimeter across the two connectors and set meter to show continuity. If there is no continuity press pedal, hopefully this will now respond. If not then the break is in the pedal. If meter idea works then it could be the socket on the keyboard, these can work loose on the pcb they are mounted to if they are used a lot.
You could open up the keyboard and look inside checking the solder joints on the socket or simply take to a Yamaha service centre.
You could also try a master reset of the keyboard, hold down the highest note whilst turning on, this will reset to factory default.
Let me know how you get on.
Nov 02, 2015 | Yamaha NP-30 Portable Grand Piano &...
Power module out
First of all measure the power output of the mains adaptor. If this is working and the polarity is correct proceed.
Plug into keyboard with a lifting movement on the plug on the end of the cable - does it turn on? If not try pushing down on the plug. Does it turn on? IF in either of these positions the socket has broken away from the PCB - you will need to resolder or fit a new socket.
If still a problem then you would need to investigate the power input lines on the board inside. If you are not technically minded probably best let to a Yamaha service centre.
Jun 15, 2015 | Yamaha P-85 Electronic Piano
Push starter button it won't turn over
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
OEM parts for Yamaha
Yamaha XJ700N Service Manual
XJ700 Suddenly won start at all Electrical Problem
1985 yamaha maxim won start
May 08, 2014 | 1985 Yamaha XJ 700 X Maxim
1985 Yamaha XJ 700 S Maxim with the key off all power stays on bike keeps running
Hi, Anonymous you may need a new ignition switch for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Oct 07, 2013 | 1985 Yamaha XJ 700 S Maxim
I have a Yamaha Clavinova clp 360; it no longer turns on.
Paul, inside of the Clavinpva at the rear where the power cable connects to the board. there is a 124 volt 1.25 amp fuse. the old type that is a glass cylinder with silver ends. it's an easy fix and will cost about $3.00 for a pack of four. You have to9 take out all of the screws on the bottom of the piano in order for the top to slide off, but you can do it in about 15 minutes!
Dec 30, 2012 | Yamaha Full-Size Keyboard
How do I reset factory settings on Yamaha p155
Turn off P155
hold top C key down (furthest white key on your right)
while holding this key down, turn on power,
keep holding key down for 3 seconds, then let go.
should default to grand piano 1 setting
Nov 14, 2012 | Yamaha P-155 Electronic Piano
Yamaha CVP-3 piano won't turn on anymore!
those pianos work forever probably the power cord.
May 26, 2012 | Yamaha Audio Players & Recorders
Key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
How do I program my clock on my 2001 Yamaha Roadstar 1600?
View the service manual at this URL : http://www.scribd.com/doc/17625151/servicemanual1602082008 : and scroll down to printed page 3-62 or electronic page 120.
Copying from that page:
1. Turn the main [ignition] switch to "ON".
2. Press both left and right buttons simultaneously [i.e., the 2 buttons below the speedometer glass] until both hours and minutes flash
3. Push the left [mode] button and the hour display will flash
4. Push the right [right] button to change the hours.
5. Push the left button and the minute display will flash.
6. Push the right button to change the minutes.
7. Push the left button and both hours and minutes will flash.
8. Push the right button for two seconds to set the clock.
Sep 01, 2010 | 2002 Yamaha Road Star
224 people viewed this question
 Grubhead
Grubhead
