Question about Epson Office Equipment & Supplies
I have an Epson 3800 printer with a clog in the black line(both matte and photo black show the problem).To unclog the head I have tried both the Fix Your Printer head cleaning solution and the Windex one. i have tried the paper towel saturated with cleaning solution under the head approach. None of them has had any effect on the clog.
    Genius:
  • 1,478 Answers
I will suggest you replace the print head since you have tried to clean it without success, in this case, replacing the print head will fix the problem.
Take care.
Posted on Aug 22, 2010
Printer heads clogged on an epson stylus photo R1800. anyone know a repair facility in the Jackson, MS area?
put the printer head in ultrasonic tub with some alcohol, it will unclog your head for sure, if you dont have one u can just plunge it in some alcohol until clogged toner leaks out, u can notice it when alcohol changes the color
Oct 25, 2011 | Epson Stylus 2200 InkJet Photo Printer
Poor print quality, not fully black with white lines through text/images.
The white lines are caused by some CLOGGED ink-jets that are not spraying the ink onto the paper at the appropriate time.
Start the Epson printer-software, and run a "print-head-cleaning-cycle", to try to UNCLOG those ink-jets.
Oct 17, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
I have an Epson NX400 printer but the yellow and black ink test pages are showing gaps and missing lines. I replaced both ink cartidges twice and did the head cleaning and nozzle check but nothing seems to...
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Jan 16, 2010 | Epson Stylus NX400 InkJet Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
My canon pixma ip1980, does not work the power ON, the cartridges were fine( they are new). please help me.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the print head?
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma 3000 won't print red
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the magenta *red.
But provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Good Luck!
Tinteiros (Ebay)
Oct 28, 2009 | Epson Stylus C86 InkJet Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
