Question about Zanussi 24 in. DA6141 Built-in Dishwasher
Hi Zanussi Dishwasher ZDT 6894 Code AL6 keeps appearing, preventing cycle from continuing. Instruction book says problem is due to drainage. However, no water is present in bottom of machine around impeller. Cycle will only continue if I manually put a few pints of water in bottom of machine, and cycle stops again when water has been drained. Machine has a single 2 way pump, replaced last year. Is the problem likely to be a capacitor controlling the pump's cycle, or is the water inlet valve likely to be the culprit. Is there a 'float valve'- is this a possible cause? Thanks! John
  • 5 Answers
SOURCE: Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Posted on Jul 18, 2007
SOURCE: zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Posted on Feb 15, 2009
  • 636 Answers
SOURCE: bosch exxceldshwasher constantly on drain,is the
There is a float on the bottom of the dish washer does this float move freely up and down? If not it is probably stuck in one position.
Posted on Aug 13, 2009
jyackle5
  • 8197 Answers
SOURCE: lost manual for zanussi zdt 5052 dish washer
You can get the manual on the link below.
http://dl.owneriq.net/7/71289b21-cfc8-4753-84be-57c46532e8d5.pdf
Posted on Jan 16, 2010
  • 901 Answers
SOURCE: Zanussi ZDT 6244 Dishwasher , wash cycle completes
Try cleaning all the jet orifices in the rotating vanes. Use tooth brush. Check for dish plate is touching the rotating arm in the wash chamber. Rotate by hand for freeness.
Posted on Mar 30, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Will not fill with water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Nov 27, 2010 | Zanussi ZT485 Built-in Dishwasher
Zanussi ZDT 6252 dishwasher will not work
Almost certainly the control board has gone faulty. The favorite is the transformer burns or the thyristor gets very hot and burns due to a bad solder joint. Quickest no noncense repair is to bite the bullet and install a new board.
Jun 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT 6244 Dishwasher , wash cycle completes , all water drains out , but the dishes are not brilliant clean & dishes are still wet
Mar 29, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Just moved in and run the dishwasher
Replace the timer.
Most likely it was broken by someone resetting the timer by hand while the unit was energized.
Always open the door(de-energizes the timer) when you want to make an adjustment to the machine while it's running.
Jun 21, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Zanussi zdt 6252
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi DE 6965
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
108 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
suelack1
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
