Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I think I overloaded the washer. Now it won't drain the water or spin.
SOURCE: Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
Posted on Aug 28, 2008
tzweeb
  • 318 Answers
SOURCE: Washer will not spin/drain properly.
a large load will sometimes get out of the top of the tub and cause the lid switch mounts to break and then the unit wont spin or drain. just look under the top and if you see the lid switch just hanging or not in the right place then replace the lid switch.
Posted on Jan 07, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
  • 4088 Answers
SOURCE: Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Posted on Aug 01, 2009
  • 68 Answers
SOURCE: my washer will not spin and drain
The load was probably unbalanced enough to trip the safety and shut the machine down. Have you tried running it again empty since then?
Posted on Nov 15, 2009
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Mar 01, 2009 | Estate ETW4400VQ Top Load Washer
Kenmore front load won't drain spins then blinks no spin
Yes this is the place, but you have to mop up the water or it would flood the place; clean out the muck from the filter and refit carefully. You have to clean your filter according to usage, the filter does not self clean, no way.
Feb 25, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
