Question about Canon Office Equipment & Supplies
My printer says that you have to load the rear paper tray. There is no rear paper tray, it is underneath. What can I do?
  • 81 Answers
Seems like you have the wrong software for the device. Try uninstalling and reinstalling.
Posted on Aug 22, 2010
Where do you load the paper?
Hi, most printers have a load area at the rear or bottom of the printer, the bottom has a pull out tray to load paper. The rear section has a "drop in tray" for paper. Hope this helps. All the best.
Feb 23, 2015 | Canon PIXMA Office Equipment & Supplies
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Canon pixma pro 100 - "support code : 1000 no paper. Load the paper in the rear tray correctly and press the RESUME button on the printer". How do I fix this?
Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Meassage reads "load paper in
The rear tray is actually the back paper support.
Canon Getting Started guide page 50, 52 on pdf.
http://gdlp01.c-wss.com/gds/6/0300002426/03/MP560_GS_U2_V2.pdf
Jan 18, 2011 | Canon MP560 All-In-One InkJet Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Aug 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Not reading paper
If you toggle the Feed Switch button (lower left side of control panel) to the Front Tray, does the printer print then? What type of paper is selected in your Printer Settings on the computer? I think that if you have selected anything but Plain Paper, the driver wants you to load the paper (photo paper, etc.) in the Rear Tray.
May 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
LEXMARK OPTRA R+ SAYS LOAD PAPER 28
Try loading paper in both trays. Tray '2' is supposed to be the bottom tray. It is a much larger tray than the top tray which sits underneath the duplexer.
IBM 4039 drivers also work for this model.
Apr 30, 2008 | Lexmark Optra R+ Laser Printer
19 people viewed this question
old marine
old marine
