Question about Olympus SP-350 Digital Camera
Sensor needs replacing. Who can do this? - Olympus SP-350 Digital Camera
    Genius:
  • 1,044 Answers
Please ask the retailer from whom you purchased the camera to give you the address of the service center for your area. If unable then look in the booklet which comes with the camera. If still it does not work out go to support in Olympus Camera web site and look for nearest service center. My advice please get this done through a authorized repairer.
Posted on Aug 22, 2010
Replace camshaft position sensor ?
need more information since each manufacturer puts the sensor in different spots --generic answer --the following link shows different vehicles sensors being replaced
How to replace camshaft position sensor in your vehicle Camshaft Position Sensor Replacement Replace Camshaft Position Sensor Yahoo Video Search Results
Aug 31, 2016 | Cars & Trucks
Tip
Kitchen aid Pro line front load gas and electric dryer fault code
PF- Power failure. Recommend that you press and hold the start button to continue the cycle or press off to clear the display.<br /> <br /> E1- Open temp sensor Recommend that you replace the temperature sensor<br /> <br /> E2- Shorted Tempurature sensor. Recommend that you replace the Temp sensor.<br /> <br /> E-3- Blower rotation failure.Recommend you check the motor and replace if needed.<br /> <br /> E-4 Tumbler rotation failure.Recommend you check the motor power.<br /> <br /> E-5 Dry rack sensor error.recommend that you check the sensor and replace if needed<br /> E-6 Exhaust high limit fault. Recommend that you check your exhaust and clean if need or replace the sensor
on Jan 02, 2011 | Dryers
How many o2 sensore are on the 99 bravado? I replaced the o2 sensor before the cat converter, now code says bank one( before cat.) needs replacing. are there 4?
the sensor before the cat is NOT an O2 sensor but a HO2S sensor ( two different sensors with different operations). If this is a V6 engine there are 4 sensors -- 2 --HO2S sensors before the cats --one for each bank cat and 2 O2 sensors after the cats.
The fault code would have spelt out the correct sensor for replacing
Jan 24, 2015 | 1999 Oldsmobile Bravada
What is making my o2 sensor fault out?
I would first want to know if the sensor is actually failing. A trouble code for a sensor is not a sign the sensor needs to be replaced, only that the data coming from the sensor is out of normal range.
Jun 26, 2013 | 1995 Toyota 4Runner
O2 sensor bank 1, need to replace, I need a
ITS VERY EASY, DISCONNECT THE NEGATIVE BATTERY, UNPLUG THE O2 SENSOR WIRE PRESSING THE TAB AND USING A 22 mm. WRENCH LOOSE THE SENSOR LIKE A BOLT
Apr 12, 2009 | 2003 Toyota Corolla
O2 Sensor
not very, but I own an 04 envoy, same engine light troubles, figured it was the o2 sensor, so I took it to my mechanic to have him tell me which sensor, so I could replace it.  Turns out the sensors are fine, but the secondary air pump is malfunctioning and needs to be replaced.  This is apparently a very common problem with this car, and I would suggest having a diagnostic ran before replacing anything, and besides, if it was an 02 sensor, there are 3 or 4 of them on the envoy and you need to know which one is failing anyway, and only a diagnostic can tell you that.
Dec 29, 2008 | 2004 GMC Envoy
Hall sensor
No. Actually, the Hall sensor, part number 6501KW2002A, is covered by a 7 year part warranty.
Dec 10, 2008 | LG WM-2277HW Front Load Washer
Crank position sensor
you just need to replace the sensor. it is independant of the distributor
Sep 12, 2008 | 1992 Honda Accord
Olympus SP-350 Digital Camera Logo
119 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
