Question about Kenwood Food Processors
I have a kenwood chef A700d which seems to have a problem with the motor brushes, as far as I can see I need to remove the moto to check and replace the brushes, can anyone give me any help as to how to remove the motor or even better any sevice manuals, my email addeass is shanecontrol@aol.com, Regards Shane
  • Angus Barron Dec 29, 2011
    Hi, I too have the same issue where I would like to replace the motor brushes but cannot seem to get the motor assembly out of the mixer casing. Any chance you could forward on that service manual?
    Cheers, Angus (gusbarron[at]hotmail.com
Need to remove external covers so i can replace a gearbox on kenwood chef km001 mixer! any ideas?
Dont know what the problem is, you didnt say.
Merely take the screws out. Usually on the bottom
of the unit. Heres your big hint, possibly. Some screws
are hidden under the rubber feet.
Jul 31, 2014 | Kenwood KM336 Chef Food Processor
How do you remove the top and motor from KM200
I have the same problem, removed screws but it won't pass over the front gearbox spigot.
May 24, 2014 | Kenwood KM200 Chef Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Where can I find a manual for the A701 food mixer
They do not have a manual for the Kenwood Chef A701. However, there is a manual for a Kenwood Chef A701 available for download see www.kenwoodservice.co.uk/instructions/UK/instructions-A701.pdf. There is also some discussion on Martin Lewis' Money Saving Expert Forum see forums.moneysavingexpert.com, about instructions for the Kenwood Chef. I hope this is of some help to you.
Thank You.
Mar 09, 2011 | Kenwood Food Processors
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
Why is smoke coming from Kenwood chef A901
sounds to me like you may have burnt up the motor probaby by mixing to heavy of a load or running it too long, or by just being older. I would replace it as fixing it would be costly
Jul 13, 2010 | Kenwood Food Processors
I have a kenwood chef mod 703c the motor spins and drives the belt ok butwhen i engage the power switch the mixerhead does nothing, does not turn
The problem is that the clutchdog, which is normally engaged by the peg on the liquidiser cover, is worn. Remove the top casing of the machine by removing the 3 screws and all of the outlet covers. Then unscrew the top of the gear box and prise open carefully with a screwdriver to expose the gears. The clutch dog can be unscrewed. Remove the spring that is on the outside of the gearbox and replace it on the inside of the gearbox so that it pulls the clutch dog down permanently. This then needs to be screwed back once the top of the gearbox has been screwed back together. Sounds complicated but it will be obvious when you try it. The machine will then turn the main attachment hub but will remain engaged as for later model machines. Hope this helps. John UK
Jun 16, 2010 | Kenwood Food Processors
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
Need a replacement bowl for my Kenwood Chef
I have an Excel that has the D shaped bowl but the base of it is round. Since the Excel does have a round base you can fit any existing bowl onto the Kenwood including their newer stainless steel bowl.
Mar 13, 2009 | Food Processors
Food Processors Logo
255 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
