Question about Homelite Garden
Used the weed eater 1 time. the next time the primer bulb will not reprime
  • Homelite Master
  • 7,482 Answers
Sounds like you have trash or debris in your carburetor jet and you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 23, 2010
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Repair weed eater
If you see gas in the primer bulb it is pulling in gas to the bulb. If not check for cracks in the bulb assembly and check to see if the fuel lines are not off their fittings and not cracked.
Jul 17, 2013 | Garden
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Took tank off weed eater and not sure how the lines go back on
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 19, 2009 | Garden
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
103 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
