Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
HITACHI TV MODEL 57F500A
BOTTOM LEFT HAND CORNER OF SCREEN APPEARS TO BE LIQUID ON INSIDE OF SCREEEN CAN SEE PICTURE BEHIND BUT SHADING IS ANNOYING AND HARD TO MISS
  • mjagitsch Aug 22, 2008
    I have the same problem. Looks like there is liquid between the screen and the protector. Can you buy replacement screens?
  • lancevan Aug 24, 2008
    Same problem on a 60" in the right lower corner. Looks like a wave starting near the middle and getting taller towards the right. It varies in shade
My hitachi 57f500a wont turn on i pulled the back off and there are only one green light on and the relay keeps clicking when the relay clicks another green light flickers and the red one come on and goes off.
Posted on May 13, 2010
Black marks on screen
my lamp problems usually start with red shades in bottom corners - red, black - same issue I think.
check your hours of filter (and clean) - clean inside your housing as helps and check lamp hours - you usually get 1500 to 3000 hours (check your user guide for lamp hours)
try and live with problem until you need new bulb as not cheap
good luck
Jan 27, 2013 | NOBO X28 original lamp
Green color all over
may need to try to adjust the screen controls down or up inside the front of the set behind the speaker grill.
May 13, 2012 | Hitachi Televison & Video
Hitachi 53udx10b issue with green and pink lines creeping in upper left corner of picture. Rear projection tv about 10 years old. Just started yesterday, didn't have any problems prior.
thath is your converce pin corner are missaligned
usely behind the front bottom panel you will find a board with some knobs for ajustement off the convergence watch to not turn every control its gone a be disaster /when you find the control panel look
for the adjust button in one off the corner usely red
if you pressed the crosshatch will appear in the screen/ watc to dont touch any electronic or tube there is a lot off highvoltage in there use care
when you got the crosshatch pattern read carefully
wich control act onthe left corner
beware about the highvoltage its dangerous if you
not shure ask someone who have knowledge about this
hope that will help you BE CAREFULL
Mar 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
Sep 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
Jan 28, 2009 | Televison & Video
I JUST BORT AN ADVENT NOTEBOOK HOW DO I PUT ON THE WEBCAM AND BLUETOOTH
hold the Fn key located in the very bottom left hand corner and at the same time, press one of the F keys numbered 1-12 with the picture of a little webcam on it. a picture will appear in the right hand corner of the screen and this means that next time you click your webcam it should be on. the webcam key on my advent notebook is F6 and i have the model 4489, it may be different for other models. i don't know how to do bluetooth - have a play with the other F keys.
Dec 21, 2008 | Recoton Advent Advent Q2035A 20" TV
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Convergence problem
no u cannot do anything on ur own u need to call an expert,
Apr 04, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Convergence
you need to replace the convergence ic'S inside the unit
Aug 17, 2007 | Sony KP-53S65 53" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
