Question about Microwave Ovens
I have a grohe model 33 790 and it is dripping so i assume the cartridge needs to be replaced. how do i get the cover off to get to it stansevey@aol.com
You shouldn't have posted this in the microwave oven section - the 33790 is a faucet!
Facing the faucet, on the right (where the lever is) the en-cap is bayonet mounted - twist and pull.
To remove the cartridge, there is a key that needs to be pullet out from the cavity , the lever unhooked and the cartridge pulls out. The replacement o-rings and special oval seals are available from Guillen in Florida.
Posted on Oct 07, 2010
Torn wave guide
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You didn't mention your brand or model number, but since you posted under Oster, I'll assume that's it.
You can contact Oster via the information in your owner's manual or get their contact information from the dealer where you purchased the oven.
Nov 27, 2012 | Oster 0.7 Cu. Ft. Compact Microwave
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
Sep 19, 2011 | Microwave Ovens
Where can i buy washers for a leaking grohe tap? live in turramurra, sydney australia.
Argent are distributors in Australia for Grohe taps.
Here are some spare parts providers in the Sydney area:
http://www.argentaust.com.au/partner/search/supplier?distance[postal_code]=2074&distance[search_distance]=100&distance[search_units]=km&x=16&y=12&=Search
Hope this helps!
Mar 21, 2011 | Microwave Ovens
I have a GE HVM1750SM1SS and was defrosting some bread without seeing that there was a metal twist tie on the wrapper. In only a few seconds the plastic on the top started to melt and drip in the oven....
It sounds like you may be talking about the stirrer cover.
For some models, the owner's manual covers how to remove it. You can download GE owner's manuals and installation instructions here.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 27, 2011 | GE HVM1750SMSS Microwave Oven
Problem # 1 display goes blank and fuzzy. Problem # 2 Microwave sparks and looks like it's going on fire.
You need display repair ($39.95) and a waveguide cover (assuming your model is DMT2420-something, the cover's part number is 66345, which you can order from the Pros here.
Jan 08, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Jan 09, 2010 | Goldstar Microwave Ovens
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Apr 21, 2009 | Microwave Ovens
4175sp microwave has no power to turntable
I assume this is Whirlpool model GH4175sp?
This answer also assumes that yours does not allow for keypad control of the turntable.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Whirlpool Microwave Ovens
Microwave inside light does not come on
Assuming everything else is working, then I would assume the bulb is out.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jul 13, 2008 | LG Microwave Ovens
Microwave Ovens Logo
333 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
