Question about Sta Rite 1 12 HP Above Ground Pool Replacment Pump 6' Cord NE642
When the pump is trying to start the motor engages but then the safety trips out. How can I get the pump to engage?
    President:
  • Sta Rite Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 27, 2010
What all safety switches are on a 1996 ford thunderbird
I think the only safety switch in the starting circuit (which just engages the starter motor to crank the engine over) would be the neutral safety switch. But if you have the anti-theft system, that will inhibit starting while honking the horn and flashing the headlights, too.
There is an inertia switch in the wiring to the fuel pump which could trip with a large bump, but it would only shut off the fuel pump, and not affect the starting circuit.
The neutral safety switch wiring would be found in the wiring to the Transmission Range sensor, which also needs checking.
Sep 21, 2015 | 1996 Ford Thunderbird LX
Car won't engage starter
At the starter relay, you have two red or purple wires, one goes to the starter and the other comes from a 30amp fuseable link. Is that fuseable link circuit hot ?
From the key switch, power goes thru the alarm relay, then the clutch safety switch or automatic selector switch, then to the starter relay. The fourth wire on the starter relay is a ground.
You should be able to put power to the starter relay on the white or yellow wire coming from the safety switch to make the relay engage.
My guess is something wrong with the alarm system.
Mar 02, 2014 | 2004 Hyundai Tiburon
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
Did not press the RIO when going in reverse with the blades engaged. The motor stopped for safety reasons. Now I cannot get the mower started. Any ideas?
What model machine, and are blades engaged by flicking a switch or by actuating a lever.
BUT .... did you place machine in neutral, apply parking brake and disengage blade PTO before trying to re-start ?? Machine's safety system needs to be satisfied that the machine is safe to re-start.
Oct 30, 2013 | John Deere Garden
Pb4 booster pump is trying to engage. It has a humming noise every 10 to 15 minutes but will not engage
turn off try spinning the back shaft of motor then try if still doesn't work need new pump or motor
Sep 01, 2013 | Polaris Pb4 - 60 Booster Pump
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Breaker trips when you try to start compressor motor spins a little before tripping breaker
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
May 04, 2012 | Craftsman 33 gal Air Compressor 6 hp...
When trying to start the dishwasher you can hear the water come in and the you should here it all engage. All you ear is a hum of an electrical motor. Then it shuts itself down. It tries again after a few...
The motor or the pump could be jammed. If it is then the motor will trip its overheat safety. When it cools down it tries to run and overheats again. See if there is anything stuck in the pump.
Aug 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Wont start
If it's not even beginning to attempt to engage the engine, it sounds like one of the safety switches on the unit may have malfunctioned. Those dead man switches will completely shut down the unit and not even allow it to start. Check to make sure nothing is engaged that could have tripped on of these.
Mar 11, 2009 | Garden
Sta Rite 1 12 HP Above Ground Pool Replacment Pump 6' Cord NE642 Logo
32 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
