Question about Troy-Bilt Garden
Pressure washer will not start - Troy-Bilt Garden
    Problem Solver:
  • 18 Answers
Drain the fuel out, then replace with the next grade up. ALSO check the fuel filter and air filters. replace them yearly. todays refotmulated gasoline is no good after 90 calendar days. there are additives on the market that help preserve the gasoline to as long as 3 years. Available at Lowes,Home Depot,WalMart,Sears and most major hardware stores.
Posted on Nov 06, 2013
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
How to start pressure washer
first check for gasoline then check if you have spark if you do your carburetor may need a clean up
Jul 10, 2010 | Honda 50 W Ar Pump 2500 Psi 25 Gpm...
Started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Jun 22, 2010 | Karcher K 593 M Electric Pressure Washer
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Garden Logo
47 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
