Question about Refrigerators
I have a whirlpool side by side and need to know how to replace the doors
  • 122 Answers
Remove covers on top of hinges with philliips screw driver, to remove hinges you will need a 5/16 nut driver or socket, after you remove 5/16 screws doors will slide off lower hinges, freezer door has water line that will need to be removed
Posted on Aug 22, 2010
How do I remove the ice water dispenser cover on my whirlpool conquest
Remove the drip tray. Using all your fingers from both hands press down on the bottom of the cover, and at the same time pull away from the door. The top of the trim has tabs that set behind the dispenser housing. To replace the trim, set the upper tabs behind the housing and press in moving down both sides till you get to the bottom.
May 02, 2017 | Whirlpool Refrigerators
I need to know how to replace the door gasket on a Whirlpool model ed5phexnq00. I don't see how to remove the door liner.
if you need a cheep gasket try www.appliancepartssolutions.com cheep parts(you will need your part #)
Jan 16, 2010 | Whirlpool ED0GTQXMQ Side by Side...
I have a side by side whirlpool water filteration system fridge and I need to know how to replace the water filter on the fridge
I can only guess because I don't know your model number. At the bottom of the fridge at the front there should be a round knob or handle about 2 to 21/2 inches, you should be able to turn this and pull out the long filter tube, take the number off it and get a new one.
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
FRIDGE NO COOL
We will need to unplug refrigerator and open the panel inside the freeze compartment examine the fan for binding and if the fan is defective it will need replaced. Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water line to the water dispenser has rotted; best way to replace
take and get a coulpling at the hardware stoe that is real tight inside of the tubing and then you can either gently pull the new line into the door after removeing the inside of the refrigerator and getting to the access to the back side of the ice and water controls and replace the tunbing. have a quick connect for the coupling at the bottowm of the freever door so that all you have to do is uncoiuple it and remove the door. Be careful not to pinch the tubing when you remove the door ever. Good Luck and you can ask me more questipons here at FixYa. Please don't forget to rate this solution fo hte answer please. Happy Neew Year!!!
Dec 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side-by-Side Fridge
unscrew the cover plates on the top door hinge there are quick connects for the elects and 3 bolts on the freezer side and just 3 bolts on the refg side before you removed the freezer door pull the kick plate and there is a water line quick connect you will need to disconnect it as the tube runs thru the hinge after the top bolts are out pull up on the door and it is off >>>Note: there are some small plastic washers on the hinge post make sure you dont lose them
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerator door has dropped 1/2 inch
that happens too all sxs ref. sometime there is an adjustment on the bottom hinge
Oct 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
