Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
I have sony KV-SW292M80 Trinitron TV. The problem is that when the T.V. is switched on after some time the select sound mode option with 5-band graphic equilizer display automatically comes again and again. This happens in both cases the T.V. is switched on by remote and manually. When this happens remote does not work and we can't do any thing.
5 Suggested Answers
  • 556 Answers
SOURCE: Sony Trinitron KV-1670 TV
please visit www.serviceinfo.com after site is open go to search and give model no Sony Trinitron KV-1670 TV. you will get the map. good luck
Posted on Sep 22, 2007
  • 556 Answers
go to web site www.serviceinfo.com it is available you will have to download.
Posted on Sep 29, 2007
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
SOURCE: trinitron sony model
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact sony service centre.........
Posted on Apr 22, 2011
Sony trinitron kv 32fx68e has 14 blinks. So to switch it on you have to try 20 to 30 times. What can be the problem. Thanks
sony trinitron kv 32fx68e has 14 blinks light. that"s mention tv have bad picture tube. replace it . good luck!
Sep 22, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tuning problem KV-21CL10
try to setting your tv in menu! and you can see the menu has air cable tv mode then select the ADD or ERASE mode! you select all channels to ADD mode! or you can auto search the program!
Oct 06, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron, no sound for TV but sound with DVD.
it could be the signal strength for your cable isn't strong enough. alot of people are encoutering similar problems ever since the digital switch over
Mar 27, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My (Sony FD Trinitron WEGA KV-32FQ) is not switching itself on?
I think your control board might be your problem can you get a signal out of the normal composite or coaxial outputs?
Suggest download this service manual first
http://depositfiles.com/files/l51shqooy
Aug 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2" black bands top and bottom
well you should clarify more but i am assuming that your tv is set on widescreen mode and the only way to get rid of the bands is by using the menus to switch your screen format
Jan 19, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
169 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
