I need a new head for Champion WQ83M! Blades a bent and worn.
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: I have several bent blades on the cutter,in the middle section
A new head would cost you as much as a new shredder. Throw it away.
Posted on Jun 11, 2009
SOURCE: CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Posted on Apr 30, 2010
A champion plug 12jyc what moter will it fit in
plugs for 350 block , 4 barrel carby 1967-19710 is j12yc
all plug descriptions have a series of letters number and letters..you can download the champion chart from the champion plug site
it works like--- this any plug that will screw in the hole will provide a spark
you have to measure the thread length in the head as the plug thread cannot be longer or shorter that that length
next the sealing is by taper or copper gasket so the plug will require the same as is in the head ( flat or taper ) whether the electrode protrudes or not depends on the application ( High speed engine etc)
there are factors that come into it as well like the heat range ---cold plugs for new engines and hot plugs for worn engines to burn the oil
Mar 13, 2017 | Cars & Trucks
Yamaha waverunner fx cruiser sho
check impellor blades not bent ! scoop grate not bent ? wear ring not badly worn ?not got some rope or debrise on impellor ?
May 26, 2014 | Boating
Husqvarna un even cut
Replace the blades sounds like the ends are worn down or your blades are bent then you would see a difference in hight of cut.
Apr 09, 2012 | Husqvarna Garden
Reasons handle shake problem
There can be many reasons , so you will need to check down the list until the problem is solved.
Worn tyres
incorrect tyre pressure
buckled wheels
worn wheel bearings
worn\loose steering head bearings
loose axle nut
worn swing arm bearings
bent disc rotors
front suspension damping too soft,
loose handle bars
bent forks or frame
May 20, 2010 | Motorcycles
2004 Sata Fe rear wiper only has contact with window for the first quarter of the wipe
The wiper arm is either worn or bent. You can purchase new wipers arms and or just bend the old one if it is just bent. I will not go into how they get bent but if it is bent the wiper arm at the apex will be higher on the bad one. Either just bend it down carefully and looking for weak or missing spring [s]. If the springs aren't missing just put new blades on both sides.
If you do not know for sure when the last time you put wiper blades on your vehicle it is time for NEW ones.
Jan 28, 2010 | 2002 Hyundai Santa Fe
Shaver is fully charged. all 3 drive shafts rotate as they should with the shaver head open. with the shaver head closed, no rotation and I hear a high pitched tone.I can rotate the cutter clades manually...
something is jamming the heads from turning. the high pitched sound is the motor trying to turn but cant. if you are certain tht ll 3 blades turn freely inside their combs, the problem must be with he retainer that holds the blades into th frame. there are metal pieces on there that can get bent and interfere with the blades. If your retainer is damaged, you can get a new one at shaveroutlet.com
Jan 12, 2010 | Norelco 7800XLCC Electric Shaver
Oct 20, 2008 | Office Equipment & Supplies
My Champion Shredder doesn't cut off after the paper goes through.
Mine now just has the same problem. On mine it was because two of the cutting blades have become bent. It still shreds, but not as fast. You have to turn it on for a split second to see all the blades. You can only see about 1/4 of the blades at a time.
There is nothing you can do. And because my blades are bent it does't dispose of paper properly and also will not turn off automatically now.
Apr 07, 2008 | Office Equipment & Supplies
144 people viewed this question
k24674
jasbo
jasbo
