Question about Keurig Special Edition B60 Coffee Maker
My Keuring just stopped working. No power in display. Electrical outlet is fine. Tried other locations with same rsult. No power. Is there something I can do to repair condition?
If press eject button,it's showing LOCKED.what can i do?
You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Jan 21, 2015 | home Audio Players & Recorders
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
I put my Microwave on for 30 min and it suddenly stopped working, suggestions?
If there is no power at all to the display or the panel then it is failure of the board. But if there is power without heating, if the turntable/fan/light works, then it can be related to failure of relay, Magnetron, Waveguide or capacitor.
Jan 31, 2013 | GE JVM1650 1000 Watts Microwave Oven
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
Whirlpool 665-13442K901 dishwasher electrical plug in shorts out
You reversed the black and white wires on what? Don't ever do that. One is the line and one is common. They are polarized for a reason.
Immediately stop using that outlet before you burn your house down. Switch the breaker off to that power circuit, then have a qualified electrician check it out.
Jan 28, 2018 | Whirlpool 24 in. Built-In Dishwasher w/...
LG 250 Volt, 18000 btu window air conditioner. Tested power on the outlet, and that is fine...but will not power up the unit. Have already tried the reset and test buttons, still nothing. Any help would be...
Take cover off of electrical compartment, locate power on off switch, see if you have proper voltage before and after switch, if power is present locate thermostat, check the same way, also look for burnt wiring, Good luck.
Mar 04, 2010 | LG Heating & Cooling
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Keurig Special Edition B60 Coffee Maker Logo
238 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
