Question about Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television
How do i connect my pdp-503cmx to cable antenna? i do not see a antenna input on the back of the tv and was wondering if it was even possible to get basic cable on this television. i have been trying the past couple days but im not good with televisions!! is there a certain cord i need to get? any help will be greatly apprecitated thanks!!!:)
Im running into the same problem - did you get yours to work? you can shoot an email to cleaninghouse@mac.com - or post here - thanks - g
Posted on Jan 23, 2011
The TV inputs screen will not recognize a Toshiba VCR I've connected to it with red,white & yellow cables.
Because many VCR were not designed to work with these types of TV and the TV has no SCART socket you might have to convert it to fit.
You can do this using a box on sale at Amazon.
http://www.amazon.co.uk/SCART-HDMI-converter-convert-connect/dp/B0092IAA3I
Mar 16, 2016 | Panasonic TC-P42C2 Plasma TV, 41.6 -...
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Televison & Video
Trying to figure out the voltage for power supply on a pdp-503cmx and cant figure it out i think it is supposed to be at 250v but i only get 122v not sure i need help!!
It sounds like you have the notorious Pioneer power supply issue. Pioneer had been replacing these free of charge. You can contact Pioneer and attempt to schedule an in home swap free of charge. While the 503CMX was on the recall list, i think the warranty extension has expired on all affected models but it won't hurt to call Pioneer and ask if they'll pay for the repair........
Jun 20, 2011 | Pioneer PureVision PDP-503CMX 50 in....
Need a remote control for Pioneer model PDP-503CMX
Here you go sir/mam
http://parts.pioneerelectronics.com/part.asp?productNum=AXD1459
Sep 24, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I heard a pop from my tv and then the tv didn't work
Anything is repairable as long as the screen isn't damaged.
The sound you heard is most likely was a capacitor that just went dead.
Solder in a new capacitor should fix the problem. It would most likely be on the power supply board somewhere.
You'll need the Service Manual for parts list, diagrams, and schematics. Here's one place for that:
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=pdp-503cmx+service+manual&forward=plist
Any other questions just ask.
May 10, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Will not come out of standby
The reported problem is either:
A) your input signal is not being received (or is too weak), so the TV remains in standby mode...check the antenna or SAT or cable connection AND be sure the selection on the remote matches the intended input
OR
B) the TV Guide feature is unable to connect to the update correctly....power down the set (unplug if necessary) for 10- 15 minutes, power on and enter 0-0-0-0-0 as the zip code for the TV Guide...
Nov 05, 2008 | Pioneer PDP-505CMX 50 in. Plasma...
Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television Logo
541 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
