Question about Canon PIXMA iP1600 Printer
Paper fials to come down to rollers from paper holder
    Problem Solver:
  • 6 Answers
The usual problem is that the pickup rubber rollers need to be cleaned as dust and paper particles collect and slick out the rollers. Just for fun to check take the top sheet and when you are ready to print put downward pressure and it and see it it works..
Posted on Aug 22, 2010
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Wont feed paper all the time
Is it modell from the picture?
Does the paper get stuck and wrinkled on one side? then it means that something is stucked in paper path - remove inks and turn the printer up side down and shake it, maybe it come out, if not use mirror and flashlight to deteck the foreign body
If the paper wont go inside at all, you have problem with pick up roller - most comon fault is that the roller holder breaks down and you do not have any pressure on paper, so no feed is possiblle
Hope that I helped
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
No paper pickup, press enter
Suspect worn and or dirty paper pickup roller. To check the roller simply open top cover and remove toner cartridge. Roller is D shaped and can easily be removed by gently pressing the two tabs outwards. This should pop out the roller from the holder. Clean roller and check for wear. If worn replace.
Feb 23, 2010 | HP LaserJet 3055 All-In-One Printer
Brother MFC 8860DN. ''No Paper'' error message and CLICKING SOUND
Pull the paper tray out, look in the top middle by the roller holder, you will see a black plastic lever (edge actuator) hanging down, it should be flush with the roller, be careful when pushing back in place.
Feb 01, 2010 | Brother MFC-8860DN Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Crazy Z33
Remove screws from back of printer. Carefully remove plastic top cover. If necessary write down the steps you have taken so that you won't have difficulties reassembling printer. Once cover removed check small feed roller at back of printer to see if there is any obstruction and also front main rollers.
Place some paper in raer holder to see if it is seating correctly.
If this fails I have further solution .
Aug 14, 2008 | Lexmark Z33 InkJet Printer
Paper jam problem
Hi, if you are having the paper jam issue , then unplug the power adapter and remove all the papers from the paper tray and if you closely look inside the input paper tray you will find rollers , move the rollers with your finger tips. open the printer cover to the extreme left you will find the cartridge holders , move the holder from left to right a couple of times , behind the cartridge holders you will find a transparent strip which is inch wide and is inch wide and firmly connected at both the ends, use a damp cloth and clean that strip . lift the printer an#d shake it firmly turn the printer upside down and gently tab on the base , look for any obstructions.
Try all these steps and if there is an issue then you have to purchase the new printer.
good luck :), let me know once you perform all these steps
May 01, 2008 | Dell 924 All-in-One InkJet Printer
Hp colouer laserjet 4500n printer 2nd paper tray dont work when i clear the printer memory it work properly for few day in this printer an error shows drum life low change the drum and tool kit
I would definitely suggest ordering the drum life kit and replace that. A lot of times the tray comes undone from the paper tray holders causing the rollers to not be able to pickup paper. Be sure all the plastic holders are snapped into place on the right paper size setting and check the rollers for dirt, glue or wear.
Jun 07, 2007 | HP LaserJet 1020 Printer
Canon PIXMA iP1600 Printer Logo
27 people viewed this question
old marine
old marine
