Question about Nokia Cell Phones
Put sim card in and it says insert sim card - Nokia Cell Phones
  • 277 Answers
Hi,when a phone says insert Sim,it means that the Sim card was not placed properly or the Sim card you are using is damaged ( You can try to confirm the simcard if it works properly by testing it on another phone).
Also thee sim tray that you fix your sim card in the phone might also be damaged.
You can try all,it most be one at of all.
Good luck.
Posted on Aug 22, 2010
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
Put in sim card and comes up insert sim ?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nov 02, 2012 | Cell Phones
Even I inserted the sim card phone shows Insert sim card?How to solve it?
Well it is either a problem with the SIM card or the phone. First you should test out your SIM card.
Put the SIM in a friend's phone. If you put the SIM card in this other phone but it still says insert sim card, then it is the SIM that is no good. If the SIM works fine in the other phone, it would be the phone that is the problem.
May 07, 2011 | Cell Phones
Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Jul 27, 2009 | Nokia 6070 Cellular Phone
''Please insert SIM card''
th sim card needs to be unlocked or its not compatable with the phones you putting them into.
1. unlcok the sim card by calling your provider
2. the phones needs the unlock code as well.
thanks for using fixya.com
Jul 17, 2009 | Cell Phones
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Mar 27, 2008 | Nokia 6270 Cellular Phone
Sim card
THIS PHONE DOESN'T USE A SIM CARD.....DUHHHHHHHHHHHHH!!
Mar 22, 2008 | Samsung SCH-a650
Cell Phones Logo
122 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
