Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
How much compression are these 25cc blowers suppose to have? also this one has a champion spark plug in it. What should the # be? Thank you, C Hodges
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
Posted on Oct 22, 2010
SOURCE: Won't start
Starting problems with 2-cycle engines are usually traced to fuel line/filter clogging due to jelling of the fuel mixture while the engine is idle. Best fix is fuel mix pretreatment with some kind of gas saver in the gas can. Marine grade additives are the best, such as 2+4 gas treatment. Now your stuck with pulling the fuel lines and blowing them clean. If the carb has a primer bulb, you can sometimes force the fuel through, but a complete cleaning is in order. Pulling the plug and putting a few drops of fuel mix directly into the cylinder head, (or in the air intake), can sometimes get the motor to fire. This proofs the problem as being fuel starvation.
Posted on Jun 05, 2010
Replace AC49 spark plug witha champion plug number
You either have an incomplete number for your AC spark plug or it is a very old, unusual or obsolete type because there are no equivalents for that number.
I suggest instead of trying to find an equivalent you should use the make and model number of your appliance and buy the recommended spark plug from the application catalogue of your choice. I am not fond of Champion plugs for no particular reason and prefer NGK.
Apr 25, 2015 | Toro Garden
Is a champion rcj6y spark plug the same as a champion cj6 spark plug. I have a cj6 spark plug in my blower & replaced it with a rcj6y plug & it hits the piston
You answered your in question they are definitely different..a plug hitting the piston can damage or even break the piston just trying to start the blower...replace it like the one removed..good luck
Sep 24, 2014 | Garden
Spark plug
Champion is the kind of plug. most are 5/8 of an inch.
Jun 14, 2013 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
My poulan pro leafblower won't start, feels like there's no compression
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
Aug 11, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Engine won't start
make sure you have fresh gas and your spark plug has spark when you pull it over, you may have to clean old fuel and varnish from carb for it to run, also make sure you have at least 60psi compression
Apr 18, 2011 | Poulan 25CC Gas BlowerVac
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Jul 11, 2009 | Ryobi Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
621 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
