Question about Ovens
Siemens microwave oven HB86k.70b
Having had the internal glass break twice after cleaning, we decided to dismantle the door and take the glass out this time. All went well, door was reassembled and put back on. Whilst the oven works fine the microwave will not work and displays an E10 message. How do I fix this?
Hoping you can help
kevin
  • 1 more comment
  • viperkev Sep 05, 2008
    yep
    I had to get the repair man in and it cost £80 to get the microwave working!!! I was not an home to see what he did, but it involved taking the unit out of the cabinet to "fix" it.
    What a lousy design, Siemens is off my buy list doing forward
  • dparker2 Oct 24, 2008
    I have teh same problem replaced Glass in door now I get a E10 message
  • Anonymous Jan 28, 2009
    I am thinking of buying this oven. Would you recommend it?
I have the same problem, have you found out the cause?
Regards
Posted on Sep 04, 2008
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Oven glass door shattered on the inside during self clean mode
The glass is replaceable. You need to get the exact glass replacement kit from the manufacturer. I had to have mine replaced about a year ago due to condensation between the 2 glass panels and was able to get the replacement for $0.00.
Suggest to Siemens that the glass on yours should not have shattered and therefore was probably defective and you may luck out and get the glass for free. It's worth a try.
Mar 18, 2010 | Siemens Ovens
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 | Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
How do I clean the glass inside the oven door. Have tried to get to glass with no sucess? I have runs on the inside that will not disapear? Thanks
Open the door to the first notch. Lift it straight up off the hinges. Next, you'll have to dismantle the door. Remove all the screws around it and the glass will be held in by another frame. Unscrew the frame, clean the window and reverse for reassembly.
Apr 22, 2009 | Kenmore 30169 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
How to Repair the internal glass in the door
it can be fixed by removing the door. Open the door and try to lift upwards. When the door has come out, dismantle it by removing the screws and when you can reach the glass frame, measure the size of the glass reqd. The glass can be bought from any glass dealer by giving the correct size. Make sure if the glass has to be tapered at the corners. When it is received, you can reassemble it yourself
Jan 15, 2007 | Whirlpool RBS245PD Electric Single Oven
Ovens Logo
711 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
