Question about Sanyo DS36930 36" TV
I have a Sanyo DS36930. Upon initial startup, the picture is either wavy or the screen size is reduced to half or less. After a period of "on" time, the problem can be fixed by turning the unit off then on again. Sometimes when you stomp on the floor in a particular area the tv will fix itself. Of course, this leads me to believe that there is something loose in the unit. What could it be?
  • debbolen Aug 23, 2010
    Thanks for the solution! If I do fix the unit, I'll add a post. Since I'm interested in a new LCD unit, I might use this as an excuse to buy!
  • 3,153 Answers
This is indicative of what is known as a "dry joint"
Intermittent problems such as this can on occasion be very difficult to trace
If you are OK working on high voltage equipment and have both the equipment and expertise it is possible to do some of these repairs yourself.
I tend to use a simple approach of disconnecting the equipment and simply checking for loose connections by unplugging boards (one connection at a time) until I have re-seated all the simple connections on the boards.
Then i would power up and check to see if the fault was fixed.
If it wasn't then I would remove the boards associated with a particular fault and check the solder side for dry joints and re-solder as needed (this requires patience and very good eyesight)
If that fails on a dry joint repair I would tend to try another board just to make sure its not a component level repair that is needed
Failure with the suspect board would lead me to maybe (depending on the time invested) move to an associated board.
If there is a lot of SMC on a board I would tend to recommend a new unit to the customer as I don't do Surface Mount Component repairs apart from some of the more common ones.
Bob
Posted on Aug 22, 2010
  • Project NOMAD
    Project NOMAD Aug 23, 2010
    LOL its the best excuse I can think of too
    "Yup honey (holding parts of TV in hand) its pooched fer sure"
    but make sure to add dirt effect to face gotta look like you tried
Change tv screen size
Refer the user manual to your TV for details about changing the aspect ratio of picture.
Jul 10, 2013 | Sanyo Televison & Video
......can you please tell me
You can download a program called IRFanview. It is free and upon installation, just open the gif file using IRfanview and then press Ctrl button + R and select your desired size for the picture. There are also presets like half the size on the upper right portion.
You can download from here --> http://www.irfanview.com/main_download_engl.htm
Mar 08, 2011 | Cell Phones
SANYO TV WILL NOT TURN ON TICKING NOISE FROM REAR
http://www.fixdevice.com/smanuals/file/6473.html Above is your service and repair manual, Below is your user manual, please use these and you should be able to get a result. http://www.retrevo.com/support/Sanyo-DS36930-TVs-manual/id/17646ag024/t/2/
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand.
Jun 18, 2010 | Sanyo DS36930 36" TV
The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Oct 25, 2009 | Sanyo DP26746 26 in. LCD Television
TV works for a while and then the picture gets a line in middle
this is most likely a capacitor that's located in the horizontal or vertical delfection stage inside the tv. If you know how to fix electronics you can work on or if you know someone else who does they can but if not you'll need to get another tv unfortunately.
Jul 01, 2009 | Sanyo DS36930 36" TV
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Display size / resolution
Hi thanks for this but no to no avail. There is nothing wrong with the display itself - everything works but the problem is that the VIRTUAL size of the screen is 1500 x 950 instead of 1440 x 900 if you get my meaning. I wish i could find a way to shrink back the virtual screen size to 1440 x 900 so that it fits the exact physical screen. ie. if i was to play a DVD on full screen i would only see 95% of the picture because the virtual screen is larger than the display. And the virtual screen would move right if I shifted my mouse to the right edge. Still puzzled.
Sep 19, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Sanyo DS36930 36" TV Logo
75 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
