Question about HP TouchSmart tx2z
My Hp tx2-1035ee system was working properly until I decided to do a default factory restore using F11, the restore seems to be fine until when it restarted. the screen continues to flicker when the Power cord is pluged in, it stops if the power cord is removed please what should I do? I don't want to cause any further complication by using the laptop in that flicker situation. please help me.
  • 64 Answers
SOURCE: hp laptop keeps restarting
If the laptop is not popping up any windows before it shuts down it could be the built in heat protection, you can see if your fan has a lot of dust by turning off the laptop off and then blowing into the area where it pulls in air. If it is popping up a window before it shuts down disconnect it from the internet and see if it does the same thing, if it stays on while discod from the internet then run your antivirus if possibl.
Posted on Mar 07, 2009
cheap to fix
  • 404 Answers
SOURCE: recovery option on boot doesn't work
its prob the partition for recovery has been deleted
or corrupted. u need to use cds now
Posted on Mar 27, 2009
rhinoking1
  • 85 Answers
SOURCE: factory restory hp pavilion dv 1000
If your OEM is original from manufacture, and this option was installed. Restart PC, at the HP intro screen type "f11" 4 times, choose recovery, make shure you choose "restore to manufature settings" gl hope this works for you.
Posted on Jun 15, 2009
gsage
  • 180 Answers
SOURCE: hp laptop 9720us screen wont brighten or dim. last
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Posted on Aug 08, 2009
  • 928 Answers
SOURCE: HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Posted on Sep 05, 2009
What button do i press to restore factory settings
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. .
follow this blog-reset factory settings
If you need any kind of technical assistance ,you can contact support cell at http://www.vtechsquad.com
Sep 02, 2012 | Packard Bell iMedia Computers & Internet
Hp compaq laptop how to restore to factory default?
Go to Start/All Programs/HP Tools/HP PC System Recovery
If this doesn't work then try pressing the F10 key multiple times during the bootup to access the recovery console.
If this still doesn't get things fixed then you need to re-install XP
If this answer helped you then do visit my blog TECHAMY
Jul 09, 2012 | HP Computers & Internet
I have tried to do a factory restore via doing a regular fActory restore and it won't let me, on the computer in question, is running windows 7 but there i have found is no option to factory restore it....
You are right there is no factory restore. You must reload the entire operating system from a recovery disc, if you don't have one you can likely buy one from HP
Aug 18, 2017 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
I had a laptop of hp pavilion dv6000 with window 7 i don't have driver 0f webcam so what should i do
At issues of this type all you need do is to backup all your documents on an external drive and run system restore to default factory settings.
Procedure:
Restart system holding down the F11 function key till you hear a beep.
This will simply activate the system restore program.
Click on advance and select system restore to factory default.
Good luck and thanks for using Fixya.
Jun 18, 2010 | HP Pavilion dv6000z Notebook
How do I restore my dell dimension L550r to fatorcy
upon powering the system press Fn+F11 this should open the dell factory defaults option screen then select restore my computer to factory defaults if Fn+F11 doesn't work try Fn+E upon powering the system. ^_^ if all else fails you can request a disc from dell including drivers to reimage the HDD back to defaults
Jun 04, 2010 | Dell Computers & Internet
I have a dv4 1125 nr while im using it the system just freez and mute and wifi symbol turn red
Run a system restore back to factory default setting.
Start system and hold down the f11 key till it rings a bell.
This will start the restore program.
Follow the system prompt.
Good luck.
Feb 05, 2010 | HP Pavilion Dv4230us Notebook
STARTUP IS IN A LOOP, THEN:STOP:c000021a
In my experience, your computer's hard drive might be fried. I took a couple computer architecture classes and this seems to be the most reasonable answer. if I were you, i would find a computer technician just to be sure. Hope this helps, good luck
here are a few websites that might help
http://healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-fatal-system-error-with-knoppix/
http://forums.techarena.in/windows-xp-support/771529.htm
Jan 01, 2010 | HP Pavilion a1610n PC Desktop
HP Pavilion 5000 USB ports are not working.''USB device not reconized''
Please have a system restore to factory default.
Remember to backup your documents.
Procedure:
Restart system and press f11 key till you hear a bell.
That will lead you.
Dec 30, 2009 | HP Pavilion dv5000t Notebook
Reboot to factory settings hp pavillion zv6000
You can use f11 key to boot your system to recovery manager and performed system recovery there to restore your system back to factory default.
Aug 05, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Want to restore pc to factory settings
If it is a HP desktop,.
Press the F11 key on your keyboard as soon as your turn on your desktop
Continue pressing F11 every 2 seconds until you see the HP Recovery Manager window.
Then select Full Recovery on the menu.
Just follow the prompts and your unit will be restored back to factory default.
If this is a newer desktop this should work.
If it's an older PC, you may need the recovery cd's. Which can be ordered from HP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | HP Computers & Internet
HP TouchSmart tx2z Logo
88 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
