Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Trying to connect my mac to my Sharp Aquos. Initially, I plugged the HDMI to DVI ports in and the display worked fine. Then I rebooted the mac and the TV screen is now blank. Disconnecting, rebooting, and power cycling the TV do not help the situation. This same thing happened 2 weeks ago. The first time I plugged the DVI cable into the mac it works fine. If the computer is turned off or disconnected, or if the TV is turned off, there is only a blank screen. The mac detects the display and I can modify the refresh rate and the resolution, but no changes there fixed the problem either.
  • 1 more comment
  • onerine Aug 22, 2010
    Sorry, wrong model number: LC-C4677UN
    I have been manually selecting the signal each time I plug in. Doesn't help, unfortunately.
    Sorry, looks like I added the comment in the wrong place. I have been manually selecting the AV source each time, but unfortunately, that doesn't help. Good thought, though!
  • Sharp Master
  • 11,800 Answers
Maybe the tv can't detect the signal coming from the Mac and it doesn't automatically switch to it. Try to select manually the correct AV source before starting the Mac.
Posted on Aug 22, 2010
  • 1 more comment
  • Azrael SRL Aug 22, 2010
    In that case the problem is definitely in the Mac: either the video card is defective or the OSX keeps losing the settings (which is quite odd). Try first to reinstall the OSX. If this doesn't fix the problem then the card is gone, replace it.
    Is there anything less invasive we can try other than reinstalling the OS? The video card has worked fine on about 8-10 other displays, so I really don't think the card is the problem. Again, this problem only occurs the _second_ time the computer is connected. The first time it works. I cannot restart the computer or the tv screen goes blank. And once the screen goes blank, it does not return whether I reboot the machine, shut off the TV or both.
    When it works, it works well without issue until I disconnect the computer or restart it. This has worked 2x randomly over the past 2 weeks if I just connect it, but I have not figured out the pattern. A friend of mine has had a similar issue with the same TV and he thinks it is related to the refresh rate setting, if that helps. I am waiting to hear from him about more specifics.
    Any additional advice would be much appreciated.
    It can't be a problem with the tv's refresh rate - if it would have been that then the tv should have displayed a Resolution Not Supported message, That assuming the tv works fine and if your friend has observed similar behaviour it might not be the case.
    You must find the problem by exclusion - start by replacing the tv for a longer time period: if the problem goes away then the tv is faulty somehow (the processor on the mainboard is iffy.
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
I am trying to connect my macbook to a sharp LCD
Are you tyring to play something off your laptop onto your TV? If yes then what you can see right now( Bigger picture of your laptop) that is correct. For no sounds try plugging in the speakers into the laptop headphone jack directly and then see it that works. If it does then the dvi-hdmi conenctor might have gone bad and needs to be replaced.
If you have other queires please reply back to this thread.
Please rate if helpful.
Thanks
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32&amp;amp;amp;quot; Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Dec 10, 2007 | Apple PowerBook G4 Mac Notebook
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
