Question about Kenwood KW85 Air Conditioner
My air conditioner keeps turning on and off Why !!!
Check your condenser drain sensor. If the drain pan on the inside unit is full, or the sensor (float) is stuck in the up (drain pan full) position, then it could cause the ac unit outside to cycle on and suddenly off repeatedly. Sometimes there is a valve on the inside unit near the blower. Some people close it during the winter. If this valve (assuming there is one installed) is closed, then when you turn the ac on (cool mode) the condensation generated will fill the pan and not drain. The water lever will rise and trigger the anti-over flow sensor to stop the ac completely, or in some units, just the compressor unit outside (that's what happened in my case). In most to all current central ac models, these sensors are installed to prevent water from leaking out and causing water damage. My answer is possibly the easiest thing to check and even fix, however there may be other problems that will require the experience of a qualified service HVAC tech.
Posted on Mar 31, 2013
  • Denise Brewster
    Denise Brewster Mar 31, 2013
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Lg blinking
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioner Fort Lauderdale
Jul 28, 2014 | LG Heating & Cooling
Air conditioner keeps turning off
Never heard of that brand. These appliances are designed to shut down and protect themselves when there are certain problems. High head (discharge) pressure (dirty or obstructed condenser coils) or low refrigerant (Freon) charge (leak anywhere in the sealed system) will cause the unit to shut down. Look to make sure that the unit's discharge is clear (not obstructed), and that the warm (condenser) coil is clean.
Dec 01, 2013 | Heating & Cooling
It won't turn on or do anything
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Heating & Cooling
Airconditioner turns on and off automatically.
It is normal for an air conditioner to turn off and on automatically. This keeps it from making the room too cold. If it has a digital thermostat, set the thermostat to what temperature you want it to be in the room. If the air conditioner has a knob that says "colder", you let the air conditioner run until the room is comfortable to you and then you turn the knob very slowly toward warmer until the air conditioner turns off, and then very slowly turn it back to colder until the compressor comes back on. It's normal for a non-central air conditioner to run the entire time you have the power turned on but the compressor, which provides the cooling, will turn on and off when only when cooling is needed.
Sep 20, 2009 | Samsung AW0603B Air Conditioner
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Kenwood KW85 Air Conditioner Logo
3,334 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
