Question about Gigabyte GA-6VXE7+ Motherboard
How do i program the jumper and the switch - Gigabyte GA-6VXE7+ Motherboard
  • 527 Answers
The jumper settings is 1 and 2 is default. 2and 3 is normal mode. without jumper it reset mode for CMOS jumper settings. which switch do u mention? let me know
Posted on Aug 22, 2010
Need image of jumper settings for l7s7a2 rev 1.1 motherboard
Elitegroup Computer Systems (ECS) Support > ECS L7S7A2 > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=267&MenuID=24&LanID=0
Click on Download.
(Features /Specification / Download / Support / FAQ / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down a little, click on the country name nearest yours, next to the Green Down Arrow.
A small window will come up on the right -
Opening l7s7a2_eng11a.zip
Make sure there is a Green dot in the small circle, to the left of - Save File.
If there isn't; left-click in the empty circle to the left of Save File.
Now go below in the window, and click on OK.
A small window will come up on the left.
Allow the file to fully download, then DOUBLE-click right on the file name.
In the next small window click on - Extract all files, to the far left.
In the next three small windows click on Next, Next, and Finish.
Finally in the last small window, DOUBLE-click right on the file name, next to the red Adobe PDF icon.
(L7S7A2_en...)
There is the motherboard manual, and the jumper settings.
IF, you cannot open this Zip file, suggest go to 7-Zip, download, and install. It is a free 'un-zip' program.
[ A Zip file is used to send large amounts of information more easily.
A Zip file is a compressed file.
You need to 'un-zip it', or uncompress it.
Requires an 'Un-zip' program.
WinZip usually comes with Windows, but may only last so long, because it is a trial version.
7-Zip is one of the free unzip programs, NO trial.
I use it ]
[NOTE*
I DOUBLE-clicked on the file name - L7S7A2, and a warning 'Squawk Box' came up from Microsoft.
Click on Run. It is OK I assure you.
[ Small primer;
Microsoft assures users that the program they are about to use, is free from Malware. (Virus, spyware, etc)
To do this they check the program out, and certify it to be OK.
This cost $$$$$$ for the software manufacturer.
Costs for the main program check, and EACH time a user downloads the software.
This = NO to most software manufacturers.
Most of the time the software is free, WHO in their right mind is going to pay each time a user downloads it? I wouldn't.
Also if I am a reputable software company, or pre-built computer company, I wouldn't either. ]
IF, somehow you cannot download the motherboard manual:
Motherboard oriented as it sits mounted in the computer case;
Processor to the Top, Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
1) To the Left side of the Processor socket is a jumper.
FIDJP1
CPU (Processor) Ratio Selector
(Multiplier)
Two columns of 5 contact pins.
Contact pin on the Bottom/Right is Pin 1.
Pins on the Right side are numbered ODD.
Pins on the Left side are numbered EVEN.
Starting on the BOTTOM of the Right side, going towards the Top;
Pins 1, 3, 5, 7, and 9.
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, 8, and 10.
Jumper on pins;
A) 1 and 2 - BIOS checks the Processor out, and automatically sets the Multiplier. (CPU Ratio Selector)
B) No jumper used -> 10.5
C) Jumper on pins 9 and 10 -> 6.5
D) Jumper on pins 7 and 8 -> 8.5
E) Jumper on pins 7-8, and 9-10 -> 12.5
F) Jumper on pins 5-6 -> 9.5
G) Jumper on pins 5-6, and 9-10 -> 5.5
H) Jumper on pins 5-6, and 7-8 -> 7.5
I) Jumper on pins 5-6, 7-8, and 9-10 -> 11.5
J) Jumper on pins 3-4 -> 10.0
K) Jumper on pins 3-4, and 9-10 -> 6.0
L) Jumper on pins 3-4, and 7-8 -> 8.0
M) Jumper on pins 3-4, and 7-8, and 9-10 -> 12.0
N) Jumper on pins 3-4, and 5-6 -> 9.0
O) Jumper on pins 3-4, 5-6, and 9-10 -> 5.0
P) Jumper on pins 3-5, 5-6, and 7-8 -> 7.0
Q) Jumper on pins 3-4, 5-6, 7-8, and 9-10 -> 11.0
The JP1 jumper is to the Right of the bottom white PCI slot.
(No.5 PCI slot)
3-pins going across in a row.
Pin all the way to the Right; is Pin 1.
Starting from the Right side, going towards the Left;
Pins 1, 2, and 3.
Turn computer OFF.
Put a jumper cap in Pins 2 and 3 for 5 seconds.
Remove the jumper cap, place back on pins 1 and 2.
Resets CMOS memory.
Just in case you are referring to the Front Panel header;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires go to, is the Front Panel header.
The Front Panel header is to the Right of the CMOS battery, and is located next to the right outside edge of the motherboard.
Two columns of pins.
IF, I am reading this correct; 5 pins on the Right side, 4 pins on the Left side.
Starting on the Bottom of the Left side, going towards the Top;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive connection.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is Reserved. (Probably 5 Volts for the factory to test )
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.ocworkbench.com/2003/ecs/l7s7a2/l7s7a2-1.htm
Nov 11, 2012 | EliteGroup L7S7A2 Motherboard
After I replace a new battery in the key,hawcan I reset the antitheft system on mu 2008 Lancer
Not reset reprogram right. To do that follow the instructions below.
1. Locate the Data Port under drivers side dashboard usually located to the right of steering column.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port terminals 1 and 4 with a
suitable jumper wire, leave the jumper wire connected throughout the programming procedure. Make sure you
know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors will
automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successful
programming, the door will lock and unlock once.
6. Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing each
programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition.
Oct 10, 2012 | 2008 Mitsubishi Lancer GTS CVT Sedan
I have installed a Utilitech timer switch #0141224 on one of three switches. The switches are all in a row but I only want the last (rightmost) switch changed out. Do I need a jumper from switch 2 to 3? ...
You are replacing single-pole switch, then 0141224 is correct choice.
It sounds like your have wiring wrong.
No jumper is needed from other switch, all you need are two wires from replaced switch plus a neutral wire.
Open following link for detailed wiring instructions and online manual.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Add a comment and ask about particular part of manual or wiring if needed.
Apr 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How to reset bios password
There are 3 ways to do this, first the easiest, changing it directly from the bios, of course if you could do that you probably would not need to. second, you will have a button / switch / jumper that will be on the bottom side of the motherboard, usually accessible through the memory or wireless card compartment. third is the actual small 3 volt battery that is hooked to the motherboard usually directly next to the button / switch / jumper.
Oct 29, 2009 | Lenovo ThinkPad® Z60t (2511FDU) PC...
How to program a new remote
1. Locate the Data Port under drivers side dashboard usually located to the right of steering column. obd-1.jpg 2. Insert keys in ignition and leave in the OFF position.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
Dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Mar 05, 2009 | Desa International White Wireless Plug In...
1996 LUMINA REMOTE
turn ignition switch to OFF position , (all power door locks will lock and unlock) . use a fused jumper wire and jump programming connector to ground . see picture , press any button on one transmitter , door locks , fuel door and trunk lid release should activate in about 2 seconds , first transmitter is now programmed , repeat this last step using a 2nd transmitter , if only one transmitter is being used , disconnect jumper wire and test remote(s) . cheers . if procedure is to technical , ask someone mechanically inclined to help .
Jan 11, 2009 | 1996 Chevrolet Lumina Mini
Keyless remote programming insyructions
95 bonny--1-turn ign switch off 2a75c3b.jpg 2-using a fused jumper wire jumper data link connector #8 blk/wht wire to #4 blk wire (look under dash for dlc)
3-press unlock button on 1 transmitter doors should lock and unlock
4-repeat step 3 if doing more than 1 remote
5-remove fused jumper
36a8224.jpgfor the 1993 car same way except jumper term a blk/wht
term g ppl/wht
have fun
Jun 28, 2008 | 1998 Pontiac Bonneville
Programing
To set to free play you simply move the wire jumpers in the credit unit. (It's the white box on the right hand side below the mechanism).
You move the two left jumpers to go from 0 to F (freeplay!) and the jumper to the right of it from 1 to 7 (maximum credits=49)
Then either switch off/on to reset or press the LT button once.
Remember that if you have programmed it for less than 100 CDs in the carousel that 00 will not work as that is technically CD 100.
Dave.
May 21, 2008 | Wurlitzer Jukebox 1015 One More Time...
My kingston flash disk physicaly write protected
Hi
In the side of the drive there is small white switch . slide the switch in the opposite side,then it will be ok
Jyo
Mar 01, 2008 | Kingston (SDCZ2-512-A10-KT)...
Gigabyte GA-6VXE7+ Motherboard Logo
196 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
