Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
The motor on my fan seems to be laboring. It won't even start when it is on low speed. Medium speed is slower than it used to be. The fan is about 2 years old. Is there a way to lubricate it or is something else recommended? Hampton bay ceiling fan uc707st
  • 2,973 Answers
The regulator could be faulty. To check remove the two wires from the regulator and join them. If the fan runs full speed then the regulator is at fault. If not then probably what you think. But fans generally do not need to be lubricated for decades. So, I feel it is the regulator.
Posted on Aug 22, 2010
Table fan winding&connection daigram
  • I have a Bionaire brand table electric fan.
    • It has a 3 speed fan motor.
    • The electric motor is a BM-122 Decomin brand 3 speed motor.
      • There are 6 wires:
        • Red wire.
        • Black wire.
        • White wire.
        • Yellow wire.
        • Gray wire.
        • Blue wire.
          • The motor has a 4mu 250volt capacitor.
  • This fan has an oscillating grill with independent sync motor, and timer circuit.
  • Something was wrong with the solid state circuitry (everything worked but the motor!), but a quick test of the motor indicated it does work.
  • The motor uses a start and run capacitor.
  • I decided to change controls to a simple mechanical switch and fore go for now anything beyond 3 speeds.
  • The printed circuit board shows the following connections:
    • Black wire
    • Blue wire
    • Yellow wire
      • Are respective for the:
        • High fan motor speed
        • Medium fan motor speed
        • Low fan motor speed
  • I think the gray wire goes out to the oscillator motor.
    • The Red wire is marked as Line, for the power source.
  • All wires are in continuity with each other EXCEPT RED is not with any other wire. How to Verify Fan Motor Wiring Connections
    • Checking the Motor and Capacitor Connections
    • Double check your connections using the fan wiring diagrams.
    • You should see that there is a separate motor winding for high speed.
      • The concern is that there is a capacitor for the motor.
      • So I'm thinking that the motor may have to start with the slower speeds first.
      • and not start in the high speed because the motor or capacitor has not been designed for that type of operation.
Sep 29, 2016 | Dryers
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
I have a sears whole house fan.The replacement motor has 2 poles ,the original has 3.The wire coming to the motor has 3 wires:black,red,white.The fan is 2-speed.This is the right motor.How should the...
The white wire is neutral which is how the current makes a complete path through the fan then back to the panel and operates the motor. the replacement switch you have is a two speed black(high) red (low) switch. If you had 3 speeds before and wish to continue getting all 3 you will need to get a compatible switch. Otherwise eliminate the medium speed (blue) wire and use the switch you have. If the fan has a wire connector system just cut the copper tip even and place a orange cap of wire cap the size that fits tightly to provide good protection.
Apr 07, 2013 | Dryers
Air condition and heat won't work
Check to see if you are getting voltage to the blower motor if you are the motor is bad if not check the fan speed switch. 1 2 3 or low medium high if you get voltage going to the switch but not from replace the switch if you have voltage from switch check the blower motor resistor the although with the blower resistor you commonly have a high fan speed in the max setting and the lower speed settings don't work wich would make you think 1 2 3 are not working but 4 is. That is why it is best to check all parts to make sure the part you do replace needed to be replaced
Oct 15, 2012 | 2000 Ford Focus
I got a 1994 ford ranger no A/c..the High/low med fan switch only works on high? whats the issue?
resistor.
Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 12, 2010 | 1994 Ford Ranger Supercab
I have a duracraft dual window fan that was disassembled for cleaning. When reassembling, the power wire became seperated at it's union with the leads to the switch. When re-wired, it runs at only one...
Many times, a simple three speed fan motor has one wire for each speed - and a "common" wire, for a total of 4 wires. The common wire is connected to one of the wires of the 2 conductor cord that plugs into the wall outlet. Each of the other three wires from the motor is connected to a separate terminal of a a four position switch (Off, Low, Medium and High speed).
The other wire from the 2 conductor cord goes to the "shunt terminal" (or common terminal) of the switch. The switch directs the power to flow from the shunt terminal to either the off position or the low, medium or high speed terminals - which power the fan motor to run at the associated speed.
What you have done was connect the wire that came off to another wire. This means that the power from the 2 conductor cord is permanently connected to one of the speed terminals - and wires of the motor. You need to unplug the fan and remove the wire that you connected. Locate the shunt terminal of the switch - it should be the one without a wire on it. Reassemble and try again.
Be careful doing this work - I hope this helped!
Aug 25, 2010 | Dryers
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
Air Conditioner/Heater
Try setting the fan to medium, when you want less air blowing pull out on the ac button. Don't change fan setting.If your blower motor is starting to fail this will cause the motor to draw too much power blowing your fan fuse. If you want to get more life out of the motor do not set the fan switch above medium and it could last a lot longer. If you have the Extra money around $150.00 for the blower motor and at least that much again for the labor unless you DIY then you may choose to replace it I did this on My 91 Dodge B350 Xplorer Van Camper last august and it is still working.
Jun 18, 2009 | Sierra Online, Inc. You Don't Know Jack...
3 speed switch wiring schmatic
On a 3 speed switch you usually have 4 terminals, and they are marked L1, 1, 2 and 3.
L1 which is line voltage from the electrical cord or wall plug, #1 low speed usually a red wire from motor, #2 medium speed usually a blue wire from the motor and #3 high speed usually a black wire from the motor. That is if the fan is low,medium and high, if it says high, medium and low then reverse #1, #2 and #3
May 08, 2009 | Heating & Cooling
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
115 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
