Manual guide for diy repairs on a Kenmore 700 series washer
SOURCE: Kenmore 700 series top load washer problem
Take the washer back. We just bought the same one and have the same problem
Posted on Apr 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Washer will not drain
Hi, When the the water is suppose to be draingin, do you hear the motor humming at all?
It could be that something is plugging the pump. You can tip the washer toward the wall and look underneath. The pump is right behind the front panel and easy to get to. You can try lowering the drain hose into a bucket and see if the water will release.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 09, 2009
  • 64 Answers
SOURCE: Kenmore 70 series washer: leaky water pump
NEW WATER PUMP
Posted on Aug 31, 2009
My kenmore elite washer keeps giving me the LE error
Kenmore elite 700 series triple action technology glass top load 5.3 cu ft.washer glass lid is shattered..can I replace the glass only or do I have to replace the whole lid top?
Mar 16, 2017 | Kenmore Washing Machines
The locked light is on and the washer won't turn on. there is a series of clicking but turn on of machine
You need the Service Manual to start working on the machine.
If you don't want to try to DIY the repair you will need to call in a repair company.
This could be a Control Board issue or issues with the Left Hand Lid Lock. We would need to go into Service Mode and see if we can activate the Lid Locks ie Lock them then release them and se if we are getting proper signaling to the Control Board. This is very non technical and i can guide thru the process at the DIY forum in this post
See this post 5th post down in the thread for the Service Manual. I vote for DIY'ing the repair..........Rich
Feb 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Kenmore 700 Series - No drain/spin
WOW, THIS IS AN EASY FIX, YOUR LID CONTROL SWITCH IS BAD, YOU CAN EASILY BYPASS THIS OR REPLACE IT, I THINK THE PART IS AROUND $25
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
