Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing f 30. What does this mean? I bought the washer this year.
  • 6,784 Answers
HI. This code is essentially a dispenser malfunction code. The F-30 will be issued when the dispenser motor cannot be driven to its correct position. The correct actions are to unplug the unit and check the mechanical linkage from dispenser motor to the top of the dispenser. If all looks ok there, move on to the connecting harness that links both the dispenser assembly and main control unit(CCU). Inspect the connections for loose fit or separated contacts. If all of the check points look ok at this point, then the actual motor will be the culprit. You will need to test it to confirm. Once you have confirmed failure, replace the motor.
To help you with the inspection and component accessing, I have included the necessary repair manual to assist. Click Her to access the manual. This manual is very large and it will take up to 10 minutes, possibly, to down load completely. Page 4-10 will guide you through the dispenser accessing procedures.
Posted on Aug 22, 2010
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Apr 23, 2014 | Maytag Dryers
What does the F30 code mean on my Maytag washer?
I just spoke to a repairman who claims he's been working on Maytag washers for twenty years and has never heard of an F-30 error code. He says all Maytag error codes are four digits, and this isn't a real thing. Like I'm lying. While he's saying this, I'm watching the F-30 code flash on my machine. My God, you can't find anybody who knows how to fix anything any more...
Sep 01, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I hate my washer I just bought it today and the stupid F51 code keeps flashing at my face
You must have bought a Whirlpool Cabrio. "F51" is an indication of an RPS Sensor on the Motor Stator, or a Main Control Board failure, or interconnecting wiring problem between the two. If you just purchased the washer, and it has a warranty, I would strongly recommend you either exercise your manufacturer's limited one-year warranty and get it repaired for FREE. Or, contact the retailer you purchased it from. Many offer a 30 day satisfaction guarantee. If not satisfied, they should either make an exchange, or offer to repair it. In any case, you should not have to pay for any repairs.
I would not recommend attempting to make any repairs yourself if this is a new purchase as you will void your warranty.
If you have any questions, please let me know. I hope this helps you.
Dec 11, 2009 | Washing Machines
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have not used my Metz 45ct-5 flash for over a year.
You may have to install new batteries, a few times. The Capacitor will **** the life out of the batteries as it builds up its charge. I have a Hasselblad D-Flash 40 this happened to. Bought as Mint. Not used in over 1 year. When I received it, I was absolutely pissed that I bought more ebay junk. But, I persisted. I think I went through 30 batteries, before the Capacitor rejuvenated itself. Try. Best of luck.
Apr 05, 2009 | Cameras
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
DE door switch problem
I bought a switch in Portugal by €7,5 and ...nothing. I bought a drain pump €18 and still not working. I have consult one tecnical expert by phone were i bought the pices and he said tha could be the pwc board (€75). Here in Portugal they quote €25 to come and €30 per first hour...I decided and I bought a new Lg with direct drive but I stored the old Lg (6 years old, without problems, and working 2 times per week)...if you try... and it works tell me ok ? Good Luck.
Oct 07, 2008 | LG WM-1832C Front Load Washer
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
