Question about Canon PIXMA iP3000 InkJet Photo Printer
Can not get solid colors even after I deep clean 5 times, still prints out in strip[es
    Problem Solver:
  • 6 Answers
Maybe your machine can't be cleaned and you need a new one. Sometimes it takes more than 5 times, especially if you haven't used it very often. Keep trying the head cleaning program. Otherwise your toner could be low.
Posted on Aug 22, 2010
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My MP530 willnot print black printed text. How do I now if the ink head is plugged and what do I do about it?
Hi ...
I would suggest you try and clean the print head and that should resolve the problem. Follow the below steps to clean the print head:
Perform a Cleaning of the print head:
Caution: Cleaning consumes a certain amount of ink. Perform Cleaning only when necessary.
Note: The pattern varies depending on the printer and version of Windows being used.
  1. Click 'Cleaning' to perform print head cleaning from the Pattern Check window and proceed to step 3 of the print head cleaning instructions. If the Pattern Check window is closed, skip this step and proceed to step 2.
  2. To perform a print head cleaning from the Maintenance window, click 'Cleaning'.
  3. When the Print Head Cleaning window is displayed, select the target ink group for 'Cleaning'.
    Note: When performing Cleaning for all colors, check 'All Colors'.
    Note: When performing Cleaning for Black only, deselect 'All Colors' and check 'Black'.
    Note: When performing Cleaning for Color only, deselect 'All Colors', and check 'Color'.
  4. After selecting the target ink group click 'Execute' to perform the cleaning of the print head nozzles.
  5. When the confirming message is displayed, check the contents, and click 'OK'.
    Caution: Although the Nozzle Check window is displayed, do not perform any other operations until Cleaning is completed.. Cleaning will take about 40 seconds.
  6. Print a Nozzle Check Pattern and examine.
  7. Perform Cleaning again if necessary.
    Memo: If the pattern is still abnormal after two Cleanings, perform up to two Deep Cleanings.
Perform Deep Cleaning of the print head
Caution: Deep Cleaning consumes a larger amount of ink than normal Cleaning. Perform Deep Cleanings only when necessary.
  1. In the Maintenance window, click 'Deep Cleaning'.
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. When the Deep Cleaning window is displayed, select the target ink group for Deep Cleaning.
  3. Click 'Execute'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  4. When the confirming message is displayed, click 'OK'. (The Power lamp will blink green and Deep Cleaning starts. The blink stops when Deep Cleaning is over.)
  5. When Deep Cleaning starts, check the contents, and click 'OK'.
    Caution: To prevent interruption of the Deep Cleaning process, do not perform any other operations until Deep Cleaning is completed. When the operation of the printer is stopped, Deep Cleaning is completed. Deep Cleaning will take about 75 seconds.
  6. Print Nozzle Check again.
    Note: If the printed pattern is still not normal, perform steps 1 through 4 of the Deep Cleaning process one additional time.
    Caution: If after two Deep Cleanings the Nozzle Check Pattern is still not normal, turn the printer off and let it sit for 24 hours or more before attempting another Deep Cleaning again. The wait time may allow dried ink in clogged print head nozzles to liquefy, and resolve the problem
If this does not resolve the problem, please reply back and we'll try the next step ...
Don't forget to vote if this helps ... Cheers :)
Aug 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
My printer will not print color
Hi.
First check if u r using compatible cartridges for your lexmark printer. You may use the following weblink to find the comaptible cartridges for lexmark printers:
If using correct carts and stil issue, then check the below info to clean the print contacts and cartridges:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier.
Try it out..
Apr 24, 2009 | Lexmark X2500 All-In-One Printer
Canon i950 printing many blank strips/areas where text should be
I'm afraid it looks like the printhead is broken. A quick google sees them at about £80. Compare this to the price of a new model. I think 5-6 years insn't too bad though
Mar 23, 2009 | Canon i950 InkJet Photo Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
My canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
42 people viewed this question
old marine
old marine
