Question about John Deere Garden
Rear hyd. won"t work 2150 lbs.pressure...steering won;t work either..seems like the controls get hard both ways where I can't push them..this happens even with no equip.attached..
  • talmadge1956 Aug 24, 2010
    come on now even I know the bellow links has nothing to do with the steering...the links are fine...thanks anyhow.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links regarding your query...
http://www.wikihow.com/Fix-the-Steering-Mechanism-on-a-Riding-Lawn-Tractor
http://www.ehow.com/how_4913674_fix-steering-lawn-mower.html
Let us know if you have something more to ask else please accept the suggestion.
Thanks for contacting fixya.com
Posted on Aug 22, 2010
How do you replace the rack and opinion on a 92 cutlass ceira
Here you are - power rack & pinion.
Except 2.2L and 1993-96 3.1L Engines
See Figure 1
  1. Raise the intermediate shaft seal and remove intermediate shaft-to-stub shaft pinch bolt.
  2. Remove the air cleaner and disconnect the pressure hoses from the steering gear.
  3. Raise and support the vehicle on jackstands, then remove both front wheel and tire assemblies.
  4. Remove the cotter pins and nuts from both tie rod ends. Using tool J-6627 or BT-7101, press the tie rod ends from the steering knuckle.
  5. If equipped with an Air Management pipe, remove the bracket bolt from the crossmember.
  6. Remove the 2 rear cradle mounting bolts and lower the rear of the cradle about 4-5 in. (102-127mm).
WARNING
If the rear of the cradle is lowered too far, the engine components nearest the cowl may be damaged.
  1. If equipped, remove the rack and pinion heat shield.
Fig. Fig. 1: Power rack and pinion assembly
  1. Remove the rack and pinion mounting bolts, then the gear assembly through the left wheel opening.
To install:
  1. Install the gear assembly through the left wheel opening and install the mounting bolts.
  2. Install the heat shield.
  3. Raise the rear of the cradle and install the mounting bolts.
  4. Install the bracket bolt to the crossmember under the air management pipe.
  5. Install the tie rod ends to the steering knuckles, install the retaining nuts and insert new cotter pins.
  6. Install the front wheels and lower the vehicle.
  7. Install the high pressure hoses to the steering gear and install the air cleaner.
  8. Install the intermediate shaft seal and the intermediate shaft-to-stub shaft pinch bolt.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Install an engine support fixture J-28467-A, or the equivalent.
  3. Raise and safely support the vehicle.
  4. Remove the tire and wheel assembly.
  5. Remove the intermediate shaft lower pinch bolt.
  6. Disconnect the intermediate shaft from stub shaft.
CAUTION
Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
  1. Remove the exhaust pipe hanger bracket near rear of frame including the brake line retainer and rubber exhaust pipe hangers.
  2. Remove the engine and transaxle mount nuts at the subframe.
  3. Support the rear of the subframe with jack stands.
  4. Remove the rear subframe bolts and discard.
  5. Lower the subframe for access to rack and pinion.
Do not lower the rear of the cradle too far, as damage to engine components nearest the cowl may result.
  1. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  2. Disconnect the power steering lines from the steering gear.
  3. Remove the rack and pinion mounting bolts and nuts.
  4. Remove the rack and pinion through left wheel opening.
To Install:
  1. Install the rack and pinion through left wheel opening.
  2. Install the rack and pinion mounting bolts and nuts and tighten to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm) on the pressure line.
  4. Install the power steering line clip to steering gear.
  5. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  6. Raise the subframe into position and install new frame mounting bolts. Tighten the bolts to 103 ft. lbs. (140 Nm).
  7. Remove the jack.
  8. Install the engine mount and transaxle mount nuts and tighten to 39 ft. lbs. (53 Nm).
  9. Install the exhaust pipe hanger bracket near the rear of frame including brake line retainer and rubber exhaust pipe hanger.
  10. Connect the intermediate shaft to the stub shaft and tighten the pinch bolt to 29 ft. lbs. (40 Nm).
  11. Install the tire and wheel assembly.
  12. Lower the vehicle.
  13. Remove the support fixture.
  14. Connect the negative battery cable.
  15. Refill the power steering reservoir and bleed the system.
  16. Check the front end alignment and adjust as necessary.
3.1L Engine (VIN M)
  2. Remove engine torque strut from engine.
  3. Install an engine support fixture J-28467-A, or the equivalent.
  4. Raise and safely support the vehicle.
  5. Remove the tire and wheel assembly.
  6. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  7. Remove the center engine and rear transaxle mounts from the frame.
  8. Remove the intermediate shaft lower pinch bolt.
  9. Disconnect the intermediate shaft from stub shaft.
CAUTION
  1. Remove the brace bolts and brace, including brake line brace.
  2. Support the rear of the subframe with jack stands.
  3. Remove the rear subframe bolts and discard.
  4. Lower the subframe for access to rack and pinion.
  5. Remove the steering gear heat shield.
  6. Remove the clip holding lines at rack assembly.
  7. Disconnect the power steering lines and O-rings.
  8. Remove the rack and pinion mounting bolts and nuts.
  9. Remove the rack and pinion unit through the left wheel well.
To Install:
  2. Install the rack and pinion mounting bolts and nuts and tighten the mounting bolts to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm). on the pressure line.
  5. Install the steering gear heat shield.
  7. Remove the jack.
  9. Install the brace and bolts including brake line brace.
  11. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  12. Install the tire and wheel assembly.
  13. Lower the vehicle.
  14. Remove the support fixture.
  15. Connect the negative battery cable.
  16. Refill the power steering reservoir and bleed the system.
  17. Check the front end alignment and adjust as necessary.
Nov 01, 2015 | Cars & Trucks
How to replace rack an pinion cutlass ciera 1992
You aren't saying what engine is in it, or whether it is manual or power steering. Here is the R/R procedure for power steering rack for all engine sizes.
See Figure 1
WARNING
To install:
2.2L Engine
CAUTION
To Install:
  7. Remove the jack.
3.1L Engine (VIN M)
CAUTION
To Install:
  7. Remove the jack.
Lumina troubleshooting
first check the condition and level of p/s fluid. if low top off first and turn your steering wheel left to right and back several times to try to bleed air out of p/s system. if p/s is still stiff or hard your p/s pump pressure output can be measured with a pressure gauge. if pressure is below specs its time to replace it. if your p/s output pressure is good then you would need to inspect your p/s hose or lines for kinks or restrictions to your steering rack. on certain model vehicles p/s sensitivity can be adjusted on the steering rack. you would need to check the vehicles service manual to see if its possible to adjust steering rack sensitivity.
Aug 29, 2014 | Chevrolet Lumina Cars & Trucks
Operation of John Deere Hyd. Control Valve on right side of transmission on a 401B Diesel tractor/loader?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
I am having trouble reinstalling my steering wheel pressure plate after having replaced the ignition,,, any suggestions?
Steering wheel pressure plate? Are you talking about the metal plate with notch's cut out all the way around the edge? If so, that would be the steering column lock plate. If the parts below it are not installed properly, it will not allow itself to seat properly. It also will only go in one way due to the splines on the steering shaft and on the inside of the hole in the center of the plate. You will also need a special tool that applies even pressure to push the plate down to compress the spring so that you can put the retaining clip on. You should also have the ignition lock turned to the run position so that the rod or pin isn't trying to push the plate back up. Hope we're talking about the same thing here.
Feb 01, 2014 | 1991 Oldsmobile Cutlass Ciera
How do you remove the Power Steering Pump and bracket. I have taken off several bolts but it still is not letting loose. Help
3.0L (VIN 3) Engine
Power steering pump mounting detail (3.0L engine)
  1. Disconnect and isolate the negative battery cable.
  2. Remove the accessory drive belt. The belt does not have to be removed from the engine.
  4. Disconnect the wiring harness connector to the oxygen sensor which is accessible through the oxygen sensor wiring harness grommet in the vehicle floor pan.
  5. Remove the catalytic converter from the exhaust manifold and remove all exhaust system hangers and isolators from the exhaust system brackets. Move exhaust system out of the way as far rearward and to the left as possible to provide access to the power steering pump.
  6. Place a drain pan under the power steering pump. Remove the power steering fluid return line hose on the front suspension cradle. Allow the fluid to drain from the pump and hose.
  7. Remove the accessory drive belt splash shield.
  8. Disconnect the power steering remote reservoir supply hose from the fitting on the power steering pump. Allow fluid to drain from the hose.
  9. Remove power steering fluid pressure line from the power steering pump and drain any excess power steering fluid.
  10. Remove the power steering fluid return hose from the power steering pump.
  11. Remove the rear support bracket mounted behind the power steering pump to the engine block.
  12. Remove the 2 mounting bolts that secure the pump to the alternator/power steering pump and belt tensioner mounting bracket.
  13. Remove the power steering pump and pulley assembly out from the vehicle. Transfer all required parts from the pump to the new replacement pump before installation.
To install:
  1. Position the front of the power steering pump up onto the mounting bracket. Torque the 2 power steering pump-to-mounting bracket bolts to 40 ft. lbs. (54 Nm).
  2. Install the rear power steering pump-to-engine block support bracket. Torque the 2 support bracket mounting bolts to 40ft. lbs. (54 Nm). Install the nut to the mounting stud behind the pump and torque to 40 ft. lbs. (54 Nm).
  3. Install the high pressure fluid line to the pump output fitting. Torque the high pressure line-to-power steering pump fitting to 275 inch lbs. (31 Nm). Be sure to inspect the pressure line O-ring for any damage before connecting the pressure line to the steering pump.
  4. Install the low pressure power steering fluid hose to the power steering pump low pressure fitting. Be sure the hose clamps are properly reinstalled and hoses are clear of the accessory drive belts.
  5. Install the accessory drive belt.
  6. Install the hose on the power steering fluid return line on the front suspension cradle. Be sure the hose clamps and heat shield tubes are correctly reinstalled.
  7. Reconnect the exhaust pipe to the exhaust manifold. Install the hangers and isolators onto the exhaust system brackets. torque the nuts and bolts to 250 inch lbs. (28 Nm).
  8. Reconnect the wiring harness connectors to the oxygen sensor. Install the wiring harness grommet into the vehicle floor pan.
  9. Install the accessory drive belt splash shield.
  10. Remove the drain pan and lower the vehicle.
  11. Refill the power steering pump reservoir with the correct amount of clean power steering fluid.
  12. Reconnect the negative battery cable. Bleed the power steering system.
  13. Run the engine and check the system for leaks and proper steering operation.
3.3L (VIN R) & 3.8L (VIN L) Engines
Rear support bracket mounting detail (3.3 & 3.8L engines)
Power steering pump mounting detail (3.3 & 3.8L engines)
  1. Remove and isolate the negative battery cable.
  2. Raise and safely support the vehicle. Place a drain pan under the power steering pump.
  3. Disconnect the wiring harness connector to the oxygen sensor which is accessible through the oxygen sensor wiring harness grommet in the vehicle floor pan.
  4. Remove the catalytic converter from the exhaust manifold and remove all exhaust system hangers and isolators from the exhaust system brackets. Move exhaust system out of the way as far rearward and to the left as possible to provide access to the power steering pump.
  5. Remove the power steering fluid return line hose on the front suspension cradle. Allow the fluid to drain from the pump and hose.
  6. Remove the accessory drive belt splash shield.
  7. Remove accessory drive belt.
  12. Remove the 3 mounting bolts that secure the pump to the alternator/power steering pump and belt tensioner mounting bracket.
  13. Remove the power steering pump and pulley assembly from the vehicle. Transfer all required parts from the pump to the new replacement pump before installation.
To install:
  1. Position the front of the power steering pump up onto the mounting bracket. Torque the 3 power steering pump-to-mounting bracket bolts to 40 ft. lbs. (54 Nm).
  2. Install the rear power steering pump-to-engine block support bracket. Torque the support bracket mounting bolts to 40 ft. lbs. (54 Nm). Install the nut to the mounting stud behind the pump and torque to 40 ft. lbs. (54 Nm).
  7. Reconnect the exhaust pipe to the exhaust manifold. Install the hangers and isolators onto the exhaust system brackets. Torque the nuts and bolts to 250 inch lbs. (28 Nm).
Nov 03, 2009 | 1997 Chrysler Town & Country
631 clark skid steer won't drive or steer the left side? the chain is still on the sprockets.
With all the hyd pressure released, need to unhook the 2 big hoses going to the hyd motor on the chain case on the left side and CAP OFF with fittings. Next start the machine and SLOWLEY move the travel control for the left side a little front and back, you should hear a loud growl from the hydrostat, showing that it is pumping under load. Dont do this long, but enough to test. No noise means the problem is in the hydrostat, possiably bad slipper plate, rotating group or both high pressure relief valves.If you have noise the problem is in the hyd motor. Good luck and be carefull!!!
May 09, 2009 | Bruder Cat Skid Steer Loader
Hyd controls get hard after machine has run ten
You got a pressure crossover problem there , main pump pressure is leaking into the servo system I would suspect the pump.
Apr 10, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
