My dekstop didnt show any screen.
I turn on my dekstop but didnt show any screen. I check already the power supply, and try to clean up the ram, video card and other but the problem still exist. The harddisk didnt show any readable but if this is the problem at least i can get into bios. Now the bios also can be entered. The pc used is pentium 4. Can u guys help me to solve for this problem. U help i will very appreaciated it.
  • 86 Answers
If you can get into bios check if it recognizes the RAM and the Hard Drive, if it does not find the hard drive, check the HD cables for untighted cable, change the power cable, look for damaged pins or wrongly inserted cable (on an IDE HD data cable),
do you hear the (tric-tric-tric) of the HD when the computer starts?, the HD may be damaged.
Try extracting the video card and reinstall pressing firmly.
pull out the mainboard battery, wait 10 sec. and restore (even better replace with new one), you will need to recalibrate the bios date and time (and other settings if they where changed).
Posted on May 04, 2008
This is my system, -K10N780SLIX3 wifi Mobo -Gtx 260 Evga card -amd phenom II X4 3.4Ghz -6gb ram -1tb WD sata HDD -1000watt power supply. And I can not get a display anymore but it starts up fine, no beep...
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
Apr 18, 2017 | Asrock Computers & Internet
Blue light on power button on, but Monitor shows "no signal"
If you tried replacing your power supply but still cannot put your PC to turn on, you should try checking your memory or your RAM. try reconnecting it, clean the lids of the RAM using an eraser, make sure you erase the lids on one direction and try reconnecting it again.
1. After reconnecting the RAM, try to unplug any hard disks connected to your motherboard, remove external PCI cards or if you have external video card remove it and use the built-in video card.
2. Make sure that the connectors from your power supply going through your motherboard is not loose, dont overtighten as it may possible that you can damage your motherboard from pushing through it.
3. Now turn on your computer, if it works, then your RAM must have been faulty or you have loose connections. Try to plug the hard disks and turn on again your computer, if you tried plugging in every devices and if theres an instance that your computer didnt turn on after you have plugged in that device, then the problem will be on that device that you have just plugged, and that made the computer from not responding.
It really helps alot if you have a spare device because you can test if, the one youre using works well by replacing it with a device that in no doubt that works well.
These are just basics on troubleshooting, and i hope it will helped you troubleshoot your PC or more computers in the future.
Any clarifications or future problems, i would be happy to help you. =)
Jan 02, 2010 | E-Machines T2862 PC Desktop
My hp a345c will not turn on. It has a flashing
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PCbuilder and the warranty is expired you can take out the bios chip andsent it someone who reprograms BIOS chips or you can buy a brand newchip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1.Full power down. Unplug the power cord from the Power supply. Then holddown the pc power button (this discharges any residual power in thecapacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3.Take out one of the RAM sticks if there is 2 or more. Swap the RAMsticks in different RAM slots. Try one stick at a time to see if youcan get the PC to boot. If this works, then the remaining ram sticksare damaged.
4. Set the Cmos jumper to clear. Power up the pc.Power down the PC. Set the Cmos jumper back to normal position, powerup the PC.
5. Unplug and replug all the power supply cables.
6.Check the powersupply function. Either by a powersupply voltage checker(20-25 dollars at local PC shop), get the supply tested at a PC shop(usually a free service), put the powersupply in a different pc, or trya different powersupply in the problem computer.
Ifthe Powersupply checks out ok, then you will have to do a process ofelimination to find out what part or parts are the culprit of theNo-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
Takeout one of the RAM sticks if there is 2 or more. Swap the RAM sticks indifferent RAM slots. Try one stick at a time to see if you can get thePC to boot. If this works, then the remaining ram sticks are damaged.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives,other PCI cards. Do this one at a time until you find the culprit. If aPOST screen, meaning you can see Anything from the PC brand name toMotherboard brand name appearing on the screen.
Jul 07, 2009 | HP Pavilion Replacement 200w Micro ATX PS3...
My computer won't boot up or something; no power led lit.
Seems to me your Ram module connector is dirty. Clean its edge connector with a soft eraser. Or if it can, transfer it to the next ram bank. Or your memory module is already dead.
Apr 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
So i was trying to change out the ram for a better on. while doing that i decided that i was going to clean out the insides, mainly cause its never been done. also while doing this, i took out the...
Make sure the cpu is seated properly. It should only go in one way. Also make sure you have applied a good thermal paste between the cpu & heatsink. Check and reseat RAM. Then try rebooting. Hope this helps.
Dec 25, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Rebuilding PC (2)
maybe the issue is your video card, try to clean your graphic card with an earaser.. rub the edge, an try to check your memory, clean it also..
Jan 10, 2008 | Computers & Internet
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
